-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   912 swap to 2.7 911 wiring problem (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1144990-912-swap-2-7-911-wiring-problem.html)
917 Star 08-18-2023 01:45 PM
I just recently started a project converting a 912 to a 911 the size motor is a 2.7 I don’t know what year it came out of but my main question is figuring out how to wire it up because I only have a 912 wiring harness and MSD box. I’m little confuse because I found a sensor on the left side of the motor where the distributor it looks like an oil pressure sensor. :confused:http://forums.pelicanparts.com/uploa...1692391400.jpg
Billthebuilder 08-18-2023 06:09 PM
2.7
Pretty sure that an oil temp sensor. You need a 77 wiring diagram and the ignition diagram for your multiple spark
917 Star 08-19-2023 01:14 PM
http://forums.pelicanparts.com/uploa...1692475432.png
Thank you so much for your help. I found a wiring diagram for a 1977 I think it makes sense now, but there is a oil pressure switch and there’s a oil sender why would they have two oil pressure switches? I understand they’re like a flow of oil going through the engine cooling it but that sensor is far away from the path of flow of oil. http://forums.pelicanparts.com/uploa...1692475922.jpg
