Renegade nose cut scraps.
Doing some reconstructive surgery on an 81 911SC. I replaced the front nose panel and the upper cross panel and battery box with JP group stuff but I need the piece that gets cut out for the lower radiator mount on a Renegade Kit. Fits between the front suspension mounts and the nose panel on the underside of the nose. If someone has this panel still please let me know. Thanks!
After reading my post I think I need to clarify that I don’t want the renegade part, but need the factory piece that gets cut out.
Could you post a picture? If it's the part I am thinking, they should sell that part new for a small amount.
Thanks for the reply Koilnzel. Trying to fill in where my hand is. You can buy a whole or partial front suspension pan with this part but seems a waste just to get this one little area. Will probably just form some sheet metal into place if I can’t find the original bit.
The sheet metal would be cost-effective if done correctly. The thread below pretty much closes that area with an rsr oil cooler mod. While you have a little more open space, it should still be doable. Theres also a company that sells premade cuts for that mod for about $100~300 if I recall correctly.
https://forums.pelicanparts.com/porsche-911-technical-forum/1023156-front-oil-cooler-duct-mod.html |
| All times are GMT -8. The time now is 10:57 AM. |
