-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Polished Case (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/25613-polished-case.html)
ViolentBlue 01-20-2000 03:04 PM
Polished Case
I'm putting a 914 1.7L into my bug, being that this is going to be a show car and weekend runner, I'm taking my time and doing it right.
I've already started polishing the case, to a liquidy smooth shine, but was wondering, does anyone know if this will cause any adverse heat problems?
I won't be polishing the entire engine, just the bottom and front, beacuse they'll be the only surfaces seen once its been converted to upright cooling.
VB
kokanee 01-21-2000 06:48 AM
just a thought on this.
you have a lot of cooling power with that upright setup. the fan (if you use the porsche type, was meant to cool a flat six, so it should be ample for a t4 application, I don't think that polishing your case would hinder cooling very much.
does the shroud have flaps? I know that you mentioned you could use a SB fan or something, but then where do you mount the alternator?
kokanee
'64 Manx 2.0L
ViolentBlue 01-21-2000 08:13 AM
I'll be using the Oregon Performance Dtm Kit, which is more like a standard bug upright kit, except it off sets the air being directed to one bank of cylinders, since a stock VW cooling unit would miss one cylinder completly because of the differences in the engine.
ViolentBlue 01-21-2000 08:14 AM
OH ya the alternator stand comes with the kit also, it bolts onto the block so the alternator will sit in approximately the same place as a type1 engine's would.
ViolentBlue 01-21-2000 08:16 AM
ViolentBlue 01-21-2000 08:22 AM
http://www.spiretech.com/~opshroud/
this is the Oregon Performance parts site, they onlt seel parts for newer watercooled stuff, but they manufacture a type4/914 upright cooling kit as well.
VB
