-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Cooling options (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/25615-cooling-options.html)
ViolentBlue 01-30-2000 06:47 PM
Cooling options
well I know of three different cooling options for a type4 engine,
1 is the type 1 style cooler, adapted using tsome of the type4 tin
2 is the Oregon Performance's DTM shroud
3 is the porsche style shroud
what other kinds of cooling is there out there for the type4/914 engine, that would fit under the decklid of a Bug?
kokanee 01-30-2000 07:47 PM
Richert, I believe has a cooling system, belt driven, that blows air downward upon the engine by a fan spun about a vertical axis (unlike any other VW/Porsche).
I don't know about reliability with the way the belt is run, as well as the fact that I believe that it doesn't have any flaps, which can lead to start up wear.
I posted Richert's address a while back in the sleeper exhaust post...
Kokanee
'64 Manx 2.0L
Mr Bill 04-10-2019 10:19 PM
Here's an option for youhttp://forums.pelicanparts.com/uploa...1554959901.JPG
Steve3 12-16-2019 09:06 AM
Lovely post
gumba 01-18-2020 04:32 PM
An oil cooler in the air stream will have much more impact on cooling vs fans blowing air over the cylinders.
JITARASIA 01-26-2020 12:38 PM
what other kinds of cooling is there out there fo audacity temp mail originr the type4/914 engine, that would fit under the decklid of a Bug?
