Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
bergmann 911 fan shroud
I'm interested in getting ideas/input/opinions on installing a Bergmann 911 fan shroud on a VW motor. Also if you bought/did the installation yourself and who you aquired it from.
joe
Old 07-21-2006, 03:47 AM
Hi,
I have never install a Bergrmann 911 style kit.
FYI : This kits is 911 "style" as the alt/fan assembly is not a Porsche part but a copy of them.
I have bought a 911 kit from Mike Sharp of Sharpbuilt Australia and is the best by far and uses only genuine 911 alt/fan.Also the well known in the US "MASSIVE TYPE IV" Jake Raby using Mikes Sharp kits instead of a DTM (if a customer reuires that).
Good luck
Old 07-21-2006, 04:42 PM
What did you put your kit on? What did you pay ?
Mine is an 1835cc type1 going in an outlaw 356 '64
thanks, joe
Old 07-22-2006, 03:55 AM
Geary's Avatar
I would consult Jake Raby first. He may tell you that a 911 kit will provide too much cooling air. Bergman's stuff is geared to appeal to the beginner mechanic. I wouldn't touch anything offered by Bernie Bergman. Too many horror stories, including a kid I knew well.
Old 07-25-2006, 09:45 AM
Thanks....that seems to be what everybody says.
Old 07-26-2006, 03:08 AM
I have not used a single 911 fan system in 3 years since my exhaustive testing that proved they overcool cylinders 1&3 and fry cylinders 2&4. While the Sharp system was the best in those tests, its not saying much at all... They also rob a solid 20-30HP, the least I saw was 19HP and the most a whopping 39HP!
If a customer requires a 911 shroud, I tell them to find someone that doesn't know the truth or doesnt't care- because I refuse to use them.
Jake Raby
Flat 6 Innovations and Aircooled Technology
IMS Solution Inventor
US Patents:8,992,089/ 9,416,697/ 9,687,974/ 9,909,369
'64 356C Outlaw,'76 912E,95’ 993,89’ 964 &'88 Carrera
Old 07-28-2006, 07:13 PM
Thanks.....I've put the idea of using a 911 shroud to rest.
Old 07-29-2006, 02:13 AM
Welcome Jake !!!
So, can you prove that the DTM is more efficient than any 911 style kit ? I think you can BUT the look of the 911 fan is awesome and cannot be duplicated with anything.
Rgds,
Jim
Old 07-29-2006, 05:52 AM
