356 Flywheel conversion to VW
Hi all, I have followed Duane Spencers book and had my 356 180mm Flywheel cut to fit a VW 200mm Kennedy stage 1 clutch at 4mm then 21.5mm cut and a 204.5 width with a 912/356 Scat Flywheel bolt and Kush Lock disk but it dont fit together.
I have about 3.5-4mm gap between the flywheel and the pressure plate when the disk is installed. It also look s like the disk is touching the flywheel nut. Any ideas what has gone wrong? Ren |
I don't know what the depth of a 356 flywheel is, but the two VW flywheels are different.
A 180mm VW flywheel is 24.0mm from the mounting face of the PP to the disc surface, a 200mm flywheel is 21.0mm. Maybe this is what's causing your problem. |
| All times are GMT -8. The time now is 11:07 PM. |
