-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   help 914 motor and flywheel in a 73 baja bug (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/470927-help-914-motor-flywheel-73-baja-bug.html)
moreguns 04-25-2009 09:39 AM
hey guys i need help what is the skinny on the flywheel from a porsche 914 I'm told i need a bus type4 flywheel but i cant find one is there any way to mod the 914 flywheel to do the job any help would be great thanks to anybody who chimes in jim
User Name 05-11-2009 10:20 AM
I don't know the differences between the914 flywheel and the type IV flywheel
you will owever need a spigot bearing adaptor when using type IV engines in bugs
I think stateside tuning sell them
they'd also be able to advise on the differences in flywheels if you have no luck anyplace else
1303RS 02-17-2010 08:31 PM
I got my type 4 flywheel/clutch kit from Kennedy. Its a type 4 center with a type 1 gear ring.
JIM DRAGTEAM 02-22-2010 02:15 PM
Hello and welcome!
The 914 f/w does not work (different offset) also needs the self support starter to work with.Where are you ? US ?
Kennedy Engineered Products (adapters/flywheel must see) if order tell it will be to a bug
Shoptalkforums.com • Index page (vw aircooled forum + ads too)
WWW.GermanLook.net (same as above forum but more specific to german look)
TheSamba.com :: Volkswagen Classifieds, photos, shows, forums, and information (really unlimited vw related ads from all over the country)
Avoid the 210mm bus flywheels is a pita go for the 215mm also Home - GoWesty Camper Products - parts supplier for VW Vanagon, Eurovan, and Bus have them.
Good luck
