-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   FS 911 engine to VW trans flywheel (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/502521-fs-911-engine-vw-trans-flywheel.html)
rst73 10-01-2009 09:01 AM
For Sale
Kennedy 200mm flywheel and clutch assy. for 2.0 to 2.7 911 engine to VW transmission.
I used this in my 70 Bus with a 2.4 911 engine and stock VW Bus transmission for about 20,000 miles. My bus was hit and the insurance company totaled my bus.
I now have a Vanagon with a 3.0 911 engine and 915 5 speed transmission.
Flywheel and pressure plate in very good condition, I recommend replacing the clutch disc.
Please email or PM me if you have any questions.
$150.00 plus shipping.
Roger
rgrago@cox.net
devotee 10-02-2009 07:14 PM
How does this work? Does the flywheel just bolt to an otherwise stock 911 engine and allow a VW clutch to be used? That should take car of the input splines, but does the VW trans just bolt to the Porsche engine without any other modifications? What VW transmissions will work? Bus, Bug, or other?
rst73 10-05-2009 09:12 AM
Flywheel info
It is a VW 200mm flywheel with a modified center. It bolts on the 911 just like any stock early 911 flywheel. The clutch is a high performance Kennedy and uses the stock VW TO bearing.
The 911 engine with this flywhhel and clutch assy. will work on any VW transmission that uses a 200mm flywheel. I used it with a 71 Type II VW transmission. You must use a self supporting starter (VW automatic & early 911 are the same SR21X Bosch starter).
Please let me know if you have anymore questions.
All the best!
Roger
devotee 10-05-2009 10:00 AM
Will the type 1 transaxle just bolt to the early 911 engine then? Or does it need an adapter plate?
rst73 10-05-2009 05:54 PM
911 Flywheel
Yes, as long as the transmission is for a 200mm flywheel. No adaptor plate is needed.
Roger
devotee 10-05-2009 07:33 PM
Hmm.. I'll have to think some more about this. gaining 1.1 litres and 2 cylinders could be fun. Do you know how big the motor is (inches)? I'd be putting it into a Ghia, so the length (and to a lesser extent the width and height) might be close.
rst73 10-28-2009 11:06 AM
911 motor in a Ghia
The engine compartment is the same that my 70 Bus had. Only minor modification is needed to fit. It would not work in a Bug because of the deck lid. Hope this helps.
Roger
sdckcrog 12-22-2009 01:29 AM
Do you still have the flywheel and clutch?
rst73 12-22-2009 07:58 AM
911 Flywheel
Yes I do still have it.
Best regards,
Roger
tuned6 01-09-2010 03:07 AM
Hey Roger. I am curious what fuel mileage did you get on the highway with either your 2.4 and now your 3 liter?
Thanks,
Christopher
rst73 01-11-2010 08:41 AM
Hi Christopher,
My 70 bus with the 2.4 I had a stock VW 4 speed gearbox and I got 15 mph average or around 17 mph on the hiway.
My Vanagon with the 3.0 I originally had a 3 speed VW automatic and the best I ever got was 11.5 mph. Now with the Porsche 915 5 speed I get around 16-17 average. I haven't taken it on a hiway trip yet since I put in the 5 speed. I'm guessing I'll get 18-19 mph. Remember it has the aerodynamics of a brick.
All the best!
Roger
