Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
928 6 speed auto?
Is any one doing and or having luck with a corvette 6 speed auto in a 928?my 80 euro 928 sbc pulls spooky hard hence the blown out 2ed gear syncro. P.o. says the motor dynoed out @ 430hp ,I'm suspecting a new and expensive transmission fix won't last no longer than the previous 2 so now I'm plotting the most effective way to go about a gear box that will stand up to this motor after I install the supercharger I'm have in mind. H.p. 2me is like money or sex ...hard 2 tell when you got too much even after its no longer good 4u..any and all though \opinions \quips are welcome
Old 03-13-2016, 09:42 AM
umop apisdn
928 Motorsports - Automatic to 6-speed Transaxle Conversion Kit For The Porsche® 928
1981 928S 4.7 ROW with KE3-Jetronic
"Be the man your dog thinks you are."
www.FrankenCIS.com
Old 03-21-2016, 03:04 PM
Arizona_928's Avatar
9 grand...
You can take dimensions are have a mount built for a hell of a a lot cheaper...
dolor et pavor
Copyright
Old 03-22-2016, 11:29 PM
Let me get this straight. ..I supply the corvette transmission, torque tube, bell housing . Then 928ms supplies 9,000$ worth of michine work ....4 that kind of money I could get a complete corvette rolling chassis with an LS engine attached. My 28 all ready has a renagade 350 with is to much 4the transmission, I've already blown out 2ed gear syncro. I don't believe in babying a car although I take good care of them. I'm trying to figure out the most cost effective way to build my dayly driver that also just happens 2b a real supper car..
Sent from my SM-N910V using Tapatalk
Old 03-23-2016, 04:27 PM
Easier cheaper way, move the gearbox to the front. bigger choice of gearbox, didn't affect the balance on mine.(3UZ Lexus engine is all alloy)
'82 928,2002 4.3 lexus quad cam VVTI V8,5 spd Auto.(at the front)BorgWarner 3.08/1 LSD-at the back-Weisach retained,Transaxle gone.Borla exhaust,XSchops Cayenne big brakes front ,968 front brakes rear.Mk4Supra m/s & servo. Alloy rad,1380kgs(3036 lbs(53%F/47%R))
Old 10-01-2016, 06:07 PM
