Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.50 average.
Seeing the sad state your car was in reminds me of my car when I found it. The body was in good shape, that was it. Just a good clean rust free body. A great starting point for a swap! I can't wait to see yours done.
Old 08-07-2011, 03:47 AM
Hey Snipes-
Yes you got it very good body. Its been slow goining this summer, been involved with boat & kids generally having a dam good time. While the car has been on the back burner, I'm starting to get the itch again. Lots of small projects interior, gauges, rebuild pedals & quick shift etc..
Chow, Jeff
Old 08-15-2011, 06:51 PM
Less brakes, more gas!
euro911sc's Avatar
Great project. I recommend ditching the cinder blocks, though. They tend to crumble and crack at teh most inopportune time...
Michael
FOR SALE:
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'03 330i Family hauler w/ extras
Old 08-17-2011, 11:53 AM
I second the removal of the cinder blocks, unless you have them filled with concrete, then they aren't really cinder blocks anymore...
I've seen them go on a almost finished project (and older ford), resulting in bodywork and a repaint....
James
1973 911T - 3.6VRAM, G50/5Speed
1978 to 1973 Turbo with RSR Look, 3.8Ltr TT, G50/6Speed
2010 GT3RS
Old 08-17-2011, 11:24 PM
Point taken on the blocks, you are showing your age though becuase they have not made "cinder blocks " since the 70s. I will fill the blocks or look into something else other than concrete/cement blocks to hold up the car.
1977 911S Targa LS1 "Nasty"
Old 08-20-2011, 10:27 AM
You can always sell your cinder blocks on craigslist.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 08-20-2011, 11:01 AM
Eschews Obfuscation
dhagood's Avatar
lololololll, that's great.
'84 Porsche 911 Targa
'97 Ford F250 Heavy Duty
'98 Volvo S70
'02 Subaru Forester
'05 VW Passat TDI
Old 08-20-2011, 11:17 AM
Yan2947's Avatar
Jeff, looking good! Keep it going! You still have a month or two before the snow falls! I am now trying to tweek my 89 but it is running great!
1989 911 LS1
Old 09-21-2011, 02:09 PM
Thanks Yan-
It is going well, not as fast as I would have liked, but I'm getting it all sorted out, trying to get it all right & look good while doing it is tough. Spending wisely etc.. Thanks for the support.
Jeff
Old 10-12-2011, 07:52 PM
masterdave's Avatar
Jeff, sounds like quite the project, I would love to see it when its done.
Dave
David Colangelo
"Porsche Accept No Substitute"
78' 911 Targa
88' 924s
31' Ford Model A
Old 10-13-2011, 07:27 AM
Thanks Dave-
I do need to update & post some pix. I will try to do it over the weekend.
Jeff
Old 10-13-2011, 08:42 PM
Winning!!!!!!!!!!
Well, slowly anyway, In addition to the normal stuff rebuilt pedals, new short shift & related bushings, I had to pull the drive-line to re-work a couple items that I didn't like. I had a drip from the rebuilt tranny right under the mount, tightened that up no leak. I did not like the way I had the engine coolant lines run and how I had the clamps set so I solved that. I installed a new clutch cable. Then I decided to put the ECU under the seat as described by RH. It really does clean up the engine bay of which I have painted white. It looks cleaner & it helps with eyesight I need to finish up some wiring then on to the interior. I want to finish what I have started before I move on to the rest of the car.
Thanks for looking,
Jeff
Old 10-19-2011, 07:46 PM
What's your radiator plan?
I'm planning a Subaru EG33 this winter & have it almost planned out. Still debating the radiator size/type.
Old 10-25-2011, 02:53 PM
Md-
I have already purchased the Radiator kit from RH (easy way, time saver). I believe the front mount to have some weight distribution advantages. When properly sealed should work as RH describes. However I will take a second look at the rear mounted deck lid setup. As I still could easily switch to the rear setup, but it's not likely. My car is being built for driving/commuting. So I will need to be durable,reliable.dependable, & cost effective. If you take a look at Yans "89 LS1 conversion" work he is using the rear mounted system, this set up has its own distict advantages as well.
Good luck,
Jeff
Old 10-26-2011, 04:44 PM
Little update
I got some wiring straightened out (lots more to go upgrades adding fuses & such) and got into the clutch cable setup need to measure. I installed foil bubble insulation with spray glue and foil tapped the seams it worked out great. I need to finish the interior carpet then the seats can go in. I'm kicking around a rear deck speaker idea but it would be a back burner for now.
I know it looks pretty cool, like a 930 interior mixing the 2 colors like the factory did. Its also cool how it will perform like one.
Old 12-10-2011, 11:34 AM
group911@aol.co's Avatar
Originally Posted by 911JeffS View Post
Will _ Thanks for looking. The car is a late 77, as I understand it you could order anything the factory offered so........
I also can't feel any seems in the wheel wells, the flares look & seem flawless! I purchased the car because I like the way the car looks & sits so no need to change it. I agree it does share the SC's good looks!
I assume you are reading the door post vin for the manufacture date.
Anything built after Aug 77 is technically a 78 model so you probably do have an SC.
Thanks,
Bob
group911@aol.com
Old 12-10-2011, 03:43 PM
I try never, ever, to ass-u-me my friend. "Trust but verify- Ronaldo Magnus Reagan" I apologize if I mis led you, writing "the car was built in late 1977" Here are the facts according to the named source below.
My Vin# WPA---(911 721 1xxx)
1977 (J Series)
VIN from To
911 S Targa US 911 721 0001 911 721 2747
source
Simon's Porsche 911 SC Site
Other 911S characteristics
A 911S rear hood badge. The car also came with the green bilsteins all around. Console included. No power options only A/C- Tail lights seem original, dated 1977. The front aluminum calipers are long gone, but no surprise there, as they were notorious leakers.
The trans was rebuilt with taller 4th & 5th gears trans also verified to be a 77 trans # 915/61 71 7 0xx
I don't doubt your enthusiasm my friend, and I agree, the car is a good looker. Who knows maybe the flares were added later. The point being the car is light & sweet, (no rust) with all the good stuff I care about, isn't that the point! The owner should really like whats in his or her garage. Price wasn't bad either $1900 Thanks for looking.
Old 12-11-2011, 09:24 AM
Things are going well, I have bought more goodies, but I have not installed them so no documentation yet. Just doing the nuts & bolts stuff. I have completed the carpet install, it looks great not to difficult. I need to run my coolant lines up front. If you have done this project you know why I'm asking, Where did you purchase the hose? What did you spend for a roll of hose at what price?
Thanx, Jeff
Old 01-16-2012, 11:23 AM
Laneco's Avatar
Don't know the question on the hose, Jeff, but if I were water-coolin' one, I'd be looking real seriously into copper or other hard-line with hoses at the ends only. As the factory oil lines under the car are hard-lines, perhaps the water lines should be as well in the interest of durability.
You could make some thing VERY workmanlike that passes along the rockers.
angela
1970 911T - Steve's car NOT Angela's...
550-A6 spyder -SS 3.2
81 Coupe "Butters" SCWDP #0036
Dad's SS - 87 Monte Carlo Aerocoupe
Traveling sucks, but it sucks a great deal less when you're driving a Porsche.
Old 01-16-2012, 02:19 PM
Hi Angela-
Interesting idea, may take a look at some aluminum or copper, but they may cost more than the rubber. The rubber being flexible makes it easier to conform to where I'm sending it. The lines would be 1 1/4 id so may be tough to bend the metal lines at home. Thanks for looking.
Jeff
Old 01-17-2012, 08:18 AM
