Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 3.80 average.
Sorry no fire up yet makin money (so I can spend it on ss exhaust) got in the way. Anyone have a list of pipes used for there exhaust ? I'm runnig manifolds so got to get around craddle is what Im interested in. Please include pix thanks
1977 911S Targa LS1 "Nasty"
Old 09-17-2016, 06:48 PM
Administrator
Dmitry at Pelican Parts's Avatar
Excellent build 911JeffS! It looks like it's going to be one nice Porsche; and the fact that you saved it from 'dying' makes the project that much better. In case you're considering adding a few final touches to it, check out our newly revamped Accessories section. We're now caring spray gun kits too to make the DIY projects more fun / less expensive. Best and luck and keep those pictures coming. We want to see the final product!
-Dmitry
Old 09-30-2016, 10:34 AM
Update
Hey Gals & Guys things are progressing, really getting sorted now . I apologize for poor documentation maybe because I mostly learn as I go. anyway ask anything you want. I have touched, fixed, or replaced, everything on this car.
1) short shift kit & bushings
2) pedal cluster brass bushings
3) full carpet with sound suppression
4) battery relocation kit to smugglers box (my own version)
5) replaced or repaired most interior (almost completed)
6) stereo with amp 6 speakers 2 tweeters
7) all gauges rebuilt installed
8) new momo wheel
9) reversed w/wipers found non working hidden issue
10) replaced entire front & rear suspension and brakes, all four wheel bearings, all bushings front n rear
11) rebuilt steering rack added bump steer kit
12) upgraded much of the porsche wiring added many new relays & fuses
13) chevy to porsche vise/versa wiring solved
14) everything targa (finishing up now)
15) wheels & tire upgrade to 17" euromeister (after exhaust)
16) fuel & return lines
17) radiator housing
18) keyed ignition switch replaced (added suggested fuses)
19) radiator expansion tank
20) third brake light added (LED)
21) weltmeister rear adjustable sway bar
The exhaust & big finish is coming. I promise I will post first start and my grin from ear to ear.
Old 01-26-2017, 03:39 PM
Yes this is awesome could you maybe take videos of the build
http://forums.pelicanparts.com/porsche-911-technical-forum/930992-new-project-76-993-gt2-widebody-ls1-subaru-box-996-brakes.html
my build is above maybe we could help each other a bit
Old 02-01-2017, 10:09 PM
Hi, Jeff nice job looks like it is coming along well. Just a quick question, where does the rad air exhaust?
Old 02-04-2017, 09:01 AM
Racer- The fuel tank is modified and battery relocated to smugglers box to make room for radiator and because the tank has been cut it allows for air escape though the bottom of the car. RJ, I wont debate how the air reacts under the car or vise versa. Its been beaten to death already. Hope this helps Thanks.
Old 02-05-2017, 06:16 PM
Home made wooden shift knob nice
Old 02-18-2017, 04:03 PM
ChrisP911's Avatar
Jeff how hard was relocating the battery to the smugglers box... Nice build
Old 03-06-2017, 05:35 AM
Ez Breezy battery cable actually reaches you have to cut crappy terminal off then you can feed it through an existing hole replace with new terminal. Then you have to extend the 3 small red wires with matching wire. I added the required fuses for the wire being used at the battery. Then any battery tray & hold downs that works for you. Post pix soon of whole job. Car in my buddy's shop now getting fitted with SS exhaust this week or so, hope to have a first fire up next week or sooner
Old 03-07-2017, 07:07 AM
The exhaust is going slower than I had hoped with the freakin blizzard, then I have my hell 2 weeks at work so slow going. Then my friend needs to make money ? Imagine the nerve of him sheesh "
"Its a freakin 911 with a freakin LS1 in it Cheesus" Lets Go!!!
We're using all SS components basicaly one pipe builders kit, two muffs, one x-pipe plus maybe at least 2 clamps 2 hangars. clamps mostly used for ease of disassembly. I will tell you that its coming out really nice. Mine, based on other great examples, might be the standard for this application with exhaust manifolds no doubt, and maybe over all. we shall see
Old 03-16-2017, 10:39 PM
Delays, Delays, but getting some more odds n ends done so still moving forward. Gonna be "done" as soon as it's done, which can't be soon enough.
Old 04-07-2017, 03:54 PM
Eng-o-neer
Tremelune's Avatar
The black carpet and handles looks fantastic with the tan leather—way better than tan all around. It will also weather better. When there is tan leather, plastic, and carpet, they all fade at different rates and it can look terrible in short order.
Sounds like the end is in sight! Don't rush the finish!
Old 04-09-2017, 12:45 PM
Trem- thanks for kind words, seems like I cant rush even if I tried. At my buddys shop so in good hands. My phone's photos are to large pp server won't except. Just installed adjustable rear sway bar very cool. Fire up is coming soon. Definitely will prime engine oil at least 3x more, remove plugs spin engine to move the oil around confirm oil pressure before Fire up.
Old 04-11-2017, 02:35 PM
Finally taking some shape, all SS, finsh another week or so, then fire up. more photos to follow
Old 05-05-2017, 04:41 AM
Plan to test fire sometime Monday afternoon. Not "drivable" maybe move it around parking lot at friends shop. Probably a good thing at this point. Chow
Old 07-30-2017, 02:47 PM
Primed engine with oil, spun starter without plugs installed. No start failed fuel pump (tip dont try ro reuse old one) To busy working can't get back to it until next week. Good news is that was only fuel leak so far.
Old 08-01-2017, 06:31 PM
Hey we're running but not perfect yet. Had lean running condition, not ideling. Have to check out the evap hose not hooked up. Gonna reseat connectors eng management stuff, haven't hooked up a VSS device not sure if that's contributing to not running right ? VSS is it just for Speedo & Tach? Check for Ground wire off or broken we will get it. Fire up on YouTube "First Fire up 911LS1" any helpful thought appreciated. Thanks
Old 10-31-2017, 04:39 PM
Are you still running a Maf sensor
Old 11-02-2017, 03:41 PM
MrRPJ, yes still running the Maf sensor, It's an after market one. Car is at my buddy shop 40 minutes away so I get there once a week at the moment. I'm gonna try to disconnect maf and fire it, along with disconnect/reconnect the rest of sensors etc. I don't think it's mechanical issue, definitely seems computer related. I welcome any other thoughts Thanks
Old 11-03-2017, 04:25 AM
I would pull the ecu take it to a shop and make sure all the vats are removed and while your there have it maffless tuned. that way you dont need to worry about mounting the maf or any issues it causes,
Ps are you running the renegade cradle?
could you measure from very bottom of the bottom bar to very top where it meets the mounts i need to know how high it is im making one but cant use the renegade one as im running a subaru box and i hoping to get the motor a little more forward
Old 11-06-2017, 06:37 PM
