Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
993TT turbo oil scavenging pump retrofit question
Hi.
I have a 90' C4 converted by Protomotive to a stage 4 twin turbo.
During an engine refresh I did recently I installed a 993TT turbo oil scavenging pump to capture and return the post turbo oil back to the case. Old Protomotive design used a gravity feed back to a tube welded to the lower valve covers.
Am having flywheel seal leaks now that all is back together. Second seal did same thing despite what I thought was much care. Have rebuilt air cooled 964 engine in past without leaks so I think I have decent knowledge and skill.
Red posts on seal thoughts... Did no see anything definitive on root cause for situations with no crank scoring or other defect issues.
QUESTION: Is it at all conceivable that my 993tt scavenge pump is contributing to my RMS leak? Did not make internal provisions for the 993 part as it looked pretty simple/obvious.
Any thoughts or typical flywheel seal issue that just needs sorted?
Joe.
Old 11-16-2011, 05:52 PM
