Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Originally Posted by itsnotanova View Post
Very cool! Any pics of the front?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 10-12-2013, 09:21 PM
What type of struts are you using?
79 911 sc
revolving rotation of Boxsters
Old 11-16-2013, 05:28 AM
The struts/shocks inserts are KONI yellow and the housings are made ( home ) to fit the 996 insert and suspension configuration.
I don't have the front flairs made up as yet, but they will be similar.
I sent out all the aluminum 996 suspension to be soda blasted so I can put some clear
paint on them. I like the look of clean aluminum, hope to do the same with the LSX engine
and G-50 transmission. The car will be white inside and out. I like to be able to see
inside the engine bay and white paint is best for that IMO.
Old 11-16-2013, 06:47 PM
Mid Engined 911 Twin Turbo
Just looking around the forum and found this post. here is a 1976 911 mid engine project my father and I are wotking on. It is a 3.2 with 3.3 piston & jugs, twin K16 996 Turbos. The back hatch is set up for the 2 into 1 intercooler. This is a track/ DE/ AUTOX/ Hillclimb car. We are running 914 trailing arms and had to move the fenders back 3.5 inches. All steel except for carbon doors. Full cage and we are hoping for 500- 540 hp out of it.This is the second intresting mid engined creation. We also have a 1965 mini cooper S running all 911 suspension and now wiring up an EJ20T engine for it! Hope you all like it!!
Old 01-24-2014, 10:32 AM
Mid Engined 911 Twin Turbo (more pics)
A Few more photos
Old 01-24-2014, 10:36 AM
Yan2947's Avatar
That wing serves a lot of purpose. Great modification!
1989 911 LS1
Old 01-24-2014, 04:28 PM
micheloaks's Avatar
Originally Posted by jamiesenna View Post
A Few more photos
broke my jaw when it hit the asphalt
post pics of mini - please. you have managed to literally tie two of my all time favourites together - rear engined?
Old 01-30-2014, 02:55 AM
JEM JEM is offline
JEM's Avatar
i would go full tube frame there is a lot of very good street rod suspebsion stuff that could be used or have a shop like art morrison build you a frame ready to put your body on
kerry
JM Motorsports
Custom Paint & Bodywork
81 911 SC ,black
73 914 V8 LS1
83 Audi Ur-Quattro,black
Old 04-03-2014, 09:17 PM
JEM JEM is offline
JEM's Avatar
if you went tube frame for your mid engine911 you could use corvette trans axle nd rear suspension
JM Motorsports
81 911 SC ,black
73 914 V8 LS1
Old 04-03-2014, 10:34 PM
JEM JEM is offline
JEM's Avatar
ot ise 928 engine trsnsaxel and front and rear suspension you can buy whole running 928's for less than the cost of a zf or mendeola trans axel keep it all porsche
jerry
JM Motorsports
81 911 SC ,black
73 914 V8 LS1
Old 04-03-2014, 11:48 PM
That's a beautiful car, attention to detail and quality is fantastic. Very few can pull off this kind of build.
I don't know about using a Corvette transmission, seems it is just too long but
honestly I don't know the detentions being considered.
Here is a few of my current pictures of my project continuing the mid-engine
theme.
As you can see there's lots of work to do !
I'm using the 996 suspension complete front and rear. The only modification was
rotating the steering rack on top of the front cross brace.
Old 04-04-2014, 12:20 AM
