-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   944 engine swap (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/746061-944-engine-swap.html)
Khafagamotors 04-22-2013 10:08 PM
944 engine swap
Hey guys I am brand new to this forum but have been a long on Vortex a long time so rest assured I have searched and not found to much information on this.
I have a 12v VR6T I have built broken in dyno tuned and then parted out my car for fear of my life : ) 424whp and 450wtq in a fwd MK II jetta is to much. That being said I kept my motor (sold everything else). I have seen one person doing a vr6 swap into a 944 and it seemed like a very snug fit and with the size of my turbo maybe not an option.
I am also in the process of building a 1.8t stroker (2.0). I think this would be a great swap intow a 944. I do love the S2 body but I am looking for a little direction here form someone who has tried this or knows how difficult it will be to make fit. Is it simply a engine adapter plate to the torque tube and fabing up some engine mounts? Not sure if a torque tube makes this an easier or harder idea?
I am guessing the 1.8t is the better motor to drop in?
Here is a few pics and a dyno run of my VRT purely for your entertainment.
http://i2.photobucket.com/albums/y1/...t/d51e0f0b.jpg
this was after the initial build
http://www.youtube.com/watch?v=js11VJ1stbk
dyno vid
Lapkritis 10-21-2013 11:46 AM
The oilpan/pickup on the vr6 interferes with the 944 cross member. You would need a custom pick up system or dry sump, to space down your cross member 1.5-3", and a custom intake manifold/mk4 flat end valve cover to gain hood clearance.
I'mThatGuy 10-21-2013 12:28 PM
Really its just gonna come down to how bad you want it to happen, yes there are issues off brand swapping anything, but with patience , research, and a little imagination its all do able... Side note I have a close friend with a mkII jetta vrt at 455 hp.... I agree fwd over 300 hp is terrifying, hopefully you decide to make it happen, there is a guy with a 993 vrt build here too, so don't forget there are plenty of roller.911s out there to build cheap too.
Lapkritis 10-21-2013 01:39 PM
I have a 944 that needs an engine and a brand new Schimmel 3.0L... I think the change in 944 suspension geometry would take some of the fun out if it. Looking at an AEB 20v instead... cheap as any engine to make 500hp.
