Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
GaryR's Avatar
Send a message via ICQ to GaryR
Putting a 3.2 in an SC questions
Put this out on the Technical Forum, didn't know this one existed! I assume "Conversion" covers diferent Porsche motors along with other permutations...
Mainly I need to know what wiring and fuel line changes will need to be done. I will be using the stock Motronic ECU and harness. I know of the notch that will need to be cut in the 915 case for the sensor, any other tips? On the Instant-G site he mentions a modification of the 14 pin plug but searching I can't find out exactly what it will take..
For fuel I would assume our local fuel line building guru can take care of that (once I know what I need). From what I can see I will be eliminating the Accumulator and going straight to the filter, not sure of the return line setup.
Thanks for any help..
Gary R.
Old 11-25-2013, 08:55 AM
When I installed a 3.6 into an SC I had the same things to change. Some of the pins are in different spots in the 14 pin plug for the two different engines. I think it was to do with starter wiring and the ignition system is built into the ecm on the 3.2 instead of a separate box on the 3.0. They are probably easiest to find by comparing wiring diagrams for the two different years . I was certain I found the info on pelican somewhere.
I made my own fuel lines with a simple brass compression fitting to join the adapter line in the tunnel.
Been more than 10 yrs and memory is fading about exact details.
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 12-31-2013, 07:01 PM
