-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   replace fuel lines in my 911 conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/828594-replace-fuel-lines-my-911-conversion.html)
lin7310948 09-06-2014 04:43 AM
i spend a lot of money and time installing braided stainless steel covered fuel lines in my 911 a couple of years ago. well i guess that they were not impervious to todays gasoline and they both developed a leak. so i decided to replace them with hard lines and ptfe lines. while i am at it i will replace the shortbell 930 tranny with a spare that i have. the shifter linkage on the hargett shifter came loose as i was shifting into third and there went the synchroes! also will replace the front cover with a cloyes two piece cover. the motor is an all aluminum 434 cubic inch solid roller sbc motor with mass flo efi!http://forums.pelicanparts.com/uploa...1410003494.jpg
http://forums.pelicanparts.com/uploa...1410003549.jpg
