-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Show your gauges on you swaps (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/864519-show-your-gauges-you-swaps.html)
ChrisP911 05-09-2015 11:34 AM
Hey guys just want to know what and where you are placing your gauges. Here is what I did. looking for a spot now for oil pressure and water temp. I am using factory Tach
http://forums.pelicanparts.com/uploa...1431196413.jpg
fanaudical 05-09-2015 08:17 PM
I removed my ashtray and used the space to mount a two-hole gauge panel for some 2-1/16" gauges. The current oil temp/pressure gauge you have will take the signals from some "common" VDO senders (you don't have to use the Porsche stuff). You'll have to look up the types of the original sender units for those gauges and then cross-reference to alternates.
lin7310948 05-23-2015 05:45 PM
livorsi gauges to include gps speedometer! gauges are fed via cpu other than the gps!http://forums.pelicanparts.com/uploa...1432428282.jpg
http://forums.pelicanparts.com/uploa...1432428300.jpg
lin7310948 05-29-2015 06:57 AM
this is the dash of my v8 austin healey...just redid it a while back. and, i used speedhut gauges...very pleased with the gps speedometer and the blue led backlighting. might have used these on the porsche but was unaware of speedhut at that time! they are available in many combos of faces, colors, rings, numerals, etc.http://forums.pelicanparts.com/uploa...1432907839.jpg
