-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   911 axle lengths (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/864709-911-axle-lengths.html)
jschatte 05-11-2015 01:38 AM
911 axle lengths
Hey guys,
Not sure if this is the best place for this thread but here goes.
I am doing an LS swap into a delorean and am reaching the final phases. I had to move the transmission forward so I need longer axles.
Stock axles are a 108mm 930 bolt pattern, 21" long. I need something in the 21.5" to 21.75" range now.
I noticed the (78-84) 911 turbo axles would be a good fit, PN 930-332-037-00. Doing some shopping around I found there are similar axles PN 930-332-037-08 for the 85-89 911 turbo which are much more affordable and easier to come by, but i am not sure how long these are and how much difference the 08 PN makes. I did read the 00 axles are 551mm long, which would be perfect.
Just wondering if anyone could confirm the lengths of both of these axles? Just getting a confirmation before i spend 500$ on axles!
Regards,
Josh
