-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   Gauge sending unit on 993 ls1 (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/866251-gauge-sending-unit-993-ls1.html)
dohc 05-21-2015 06:24 AM
Hi guys !
I need the oil pressure and coolant temp sending units with correct VDO output. Any input please ? Already contacted renegade hybrids.
DOHC
JJK78-951 05-21-2015 12:07 PM
Well the factory oil sending unit is part number 928 606 203 04 which I think should get that going... but which gauge are you using for "coolant", oil temp? If so the part number you seek for the oil temp sensor is 911 606 112 00. I guess you could plumb it into the block and the gauge wouldn't know the difference in what it was measuring :)
Hope this helps.
J
dohc 05-22-2015 06:23 PM
Thanks ! Got my info from Steve of RH. If anybody wants the info I'll post it.
Dohc
