-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   914 tranny into rear engine baja (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/88238-914-tranny-into-rear-engine-baja.html)
secretazn 11-20-2002 07:20 PM
I have a coplete 914 in my garage, i was wondering if i could use the tranny to be a rear mount instead of a mid mount?
Also is there any thing else i should consider using besides the rear disc brakes and engine? what about the fron discs?
thanks,
Aaron
red-beard 08-22-2003 11:47 AM
The tranny for the 914 runs in the opposite direction as the mide engined cars.
You can "Flip the differential" so that it runs 911 style, but this involves removing the gear stack and the differential.
James
Geary 08-25-2003 07:40 AM
If your baja is for off-road, I would advise against using the 901/914 series transmission. You would be better off with a VW Type II.
