G50 5sp main shaft length
Hi, are all g50 5sp main shafts the same length? . i know people shorten them but i need to go the other way and need one slightly longer at the clutch spline area.
it's a g50/00 btw.:) |
The turbo ones are approximately 30mm longer.
ah cool thanks. Iv'e worked out i need a extra 15mm of spline on the shaft. :)
Why would you shorten it?
Would any one know what grade of steel the main shaft is made from ? need to get the correct welding rods before starting to modify my shaft.:)
