Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
so i decided to freshen up the motor, lucky i did as the heads were ****ed, i got a set of 241s that look in great shape. all I need now is a rear hump sump. Any one got one??????
almost back together I just need to adjust the hood, fit the fender flares and fuel door.
Old 05-14-2018, 04:42 PM
cooling system is finished and crade is all finished and off to the powder coaters.
Old 05-14-2018, 04:46 PM
Nice. What modifications did you have to do to get the radiator to fit up front like that?
Old 05-14-2018, 07:05 PM
Think factory RSR oil cooler recess just bigger
Old 05-14-2018, 10:08 PM
SDFla7Nose's Avatar
How low is your car,. Im planning on running a canton road race s13 pan that is front sump like your (i assume) GTO pan,. And that picture has me worried for ground clearance.
-1977 911s Flachbau Coupe sunroof delete. Color TBD, 400hp Ls1/930 box. Basket case rebuild in progress. Short term.money pit
-1973 Toyota Celica GT. White. The long term money pit
-1969 Ford Mustang Mach I. 351w/TKO600. The inheirited money pit.
Old 05-15-2018, 08:47 AM
MrRPJ I dig the cooling set up. Which Jeep radiator & type of piping are you using? Did you happen to weigh the pipe?
Old 05-15-2018, 02:11 PM
right now in that pic the sump is 140mm from the ground but im changing to a rear hump sump as my cradle doubles up as a bash plate
All up the pipe work was about 4kg I just brought straight lengths and bent them with a mates bender.
Old 05-15-2018, 04:00 PM
The rad is from an 87 jeep
Old 05-15-2018, 04:03 PM
SDFla7Nose's Avatar
oh wow thats way more than it looks yeah, my main reason for wanting to run this pan is i doubt the effectiveness of a stock F body pan for oil control with the engine backwards, whereas this RR pan has oil control baffles for all directions. I was thinking of doing something along the line of these, but for the rear
https://www.summitracing.com/parts/grn-350222?seid=srese1&cm_mmc=pla-google-_-shopping-_-srese1-_-granatelli-motor-sports&gclid=CjwKCAjwiurXBRAnEiwAk2GFZhDU1TZqiAUuWrSnCULi q9qT8Tbm-Dpk9GgK-F7PvrSmDWwSZxTKARoCQhgQAvD_BwE
basically just a small, nylon, high durometer wheel for when the cradle contacts the ground to provide a rolling surface to prevent damage
Old 05-15-2018, 08:30 PM
Interesting. When I tried testing out a radiator in the same location on my 964, even a the small 3rd center radiator on the 996s/boxsters weren't able to fit in that area with the bumper cover on.
Old 05-16-2018, 07:53 AM
I love this build. Can you post some detail photos of your rsr cut out. I've been stuck at the cooling stage of my build for awhile. I actually tried the oem Cherokee radiator but felt it was too big. I was considering welding 2 yamaha rhino radiatoms together. Any pics will be greatly appreciated. I'd also like to know how you avoidea crimping the AL tube. Thanks
Old 05-16-2018, 01:41 PM
Thats the reason for the 993 kit. the 993 front bar has a lot of room behind it
Old 05-17-2018, 10:22 PM
Rhardy go back one page and I have photos of the recess
Old 05-17-2018, 11:20 PM
Welding in shorts, that's awesome.
Welding in shorts is probably one of the most Australian things I've seen. You Ausies Rock man!
shout out to the old man for helping out for the day
Old 05-30-2018, 05:47 AM
i brought a jeep radiator and the fit is perfect. it fits the front bar like it was made for it.
Funny thing is my brother is huge Jeep guy, and he suggested a Cherokee radiator also, that's sweet that it fits, and that it's big enough to cool that beast powerplant you've got in there.
Old 05-30-2018, 05:53 AM
Ok after a big weekend we have made some decent progress. I got the cradle back from powder coaters*
I started making my raised shifter box
I got the motor stripped down, rebearing the bottom end and fitted MLS gaskets throughout.
started reassembly
all finished and bolted up to the Subaru trans and fitted to the cradle
and its in took 25mins to install
Got the GT2 front flares fitted up
and all in
Old 06-06-2018, 11:21 PM
Administrator
Eric at Pelican Parts's Avatar
That's looking good there! Getting closer and closer to finishing!
I spy an ARB bull bar... is that one for a Hilux?
17 Macan GTS
97 240SX
94 Land Cruiser
Too many Miata's to count.
Old 06-07-2018, 10:24 AM
Its actually for a Holden Rodeo but Hilux bullbars are super common here in Oz
Old 06-07-2018, 03:34 PM
Old 06-20-2018, 05:13 PM
Administrator
Looks like you're on the home stretch now!
17 Macan GTS
97 240SX
94 Land Cruiser
Old 06-21-2018, 11:39 AM
