Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
I fitted a Subaru transaxle and it fits!
So im going to be doing so testing for a new gearbox thats going to be offered as an alternative for the 901 and 915. Smoother shifts, cheap rebuilds, cheap clutches, better ratios. I have just fitted it to my sc and ill be testing it in the upcoming months. I will be putting about 400hp through it and report back. Its fitted with CNC'd 930 output shafts and has sightglass to make things easy. Along with an LSD
Old 03-08-2018, 07:48 PM
PRO Motorsports
Tyson Schmidt's Avatar
How will you convert it for rear engined use?
Flip the ring and pinion? Or run it upside down?
Or just live with one forward gear and 5 reverse gears?
Old 03-08-2018, 09:21 PM
Bill Douglas's Avatar
Good engineering skills. I have trouble even making the correct stuff work. I hope it all works out well for you.
see www.lyallbaybeach.co.nz
Old 03-08-2018, 09:31 PM
Functionista
manbridge 74's Avatar
Stout.
What she weigh?
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-08-2018, 09:40 PM
Interesting. I look forward to hearing more.
Old 03-08-2018, 09:54 PM
Looks massive. Weight?
Old 03-08-2018, 10:08 PM
300hp 1800lbs is the goal
pksystems's Avatar
Subbed for for when I fit mine. You used subarugears swap parts I'm assuming? Looks great.
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
I would rather be driving
jpnovak's Avatar
This has been done before.
Do you have a solution for the select shaft that has to go above the torsion tube? This means a hole in the hump on the rear seat pans and a linkage above the tunnel. Not sure many will be willing to drill that hole.
I put a Suby drivetrain in my 914. Rigged a cable shift and it was so much better than the 914 gearbox. 4 times the stock HP value didn't hurt either.
72 911T project car. "Minne" - A tangy version of tangerine
classicautowerks.com - EFI conversion parts
Old 03-09-2018, 03:16 AM
Originally Posted by manbridge 74 View Post
Stout.
What she weigh?
55kg
its all been done, full custom internals
55kg
hole is cut and raised shifter box is made, the sorta person that fits an LS1 doesnt worry about cutting a hole haha. think hargett shifter
Old 03-10-2018, 06:23 AM
which way does a stock Subaru gearbox turn when put in a 911 unmodified ?
My guess is more reverse gears than you need as a Subaru motor runs the "correct" way and not reverse like a Corvair
looking for information about old VW Coach built based sports cars, or photos and stories from the past ,
At one time many of these got confused as "Porsche prototypes" including the one restored at Hill and Vaughn in Santa Monica
Old 03-11-2018, 02:27 PM
pksystems's Avatar
Subarugears make a reverse r&p gear to get 5 forward gears
Old 03-11-2018, 06:39 PM
gearhead
Stout.
What she weigh?
Not really stout. In the WRC days it was called the glass gearbox. Once the cars started going over 350hp they had major reliability concerns. The gears themselves are no wider than 915 gears. I've ripped teeth off with a stump-pulling 150 AWHP.
1974 911 Restorod
1974 914 Bumble Bee
1975 911S Tom's Targa
2008 Cayman S Mule
Old 03-13-2018, 07:00 AM
I have experience with high power in the 5 speed boxes. It can take 300 WHP as long as you don't launch from a dead stop. The 6 speed STI gear box can take all kinds of abuse though. It is about 100 lbs heavier and much larger.
Old 03-20-2018, 01:43 PM
gearhead
We're putting 800whp through the 6spd boxes. It's a totally different beast.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 03-21-2018, 06:26 AM
fit some blast plates. problem solved
Old 03-21-2018, 05:28 PM
Can you post us some picks of the car, what year....etc?
Very interesting.
Old 04-01-2018, 10:07 AM
gearhead
Blast plates only address case flex. They won’t make the gears wider.
1974 911 Restorod
1974 914 Bumble Bee
2008 Cayman S Mule
Old 04-05-2018, 06:14 AM
Very interesting.
LS1 GT2 911 Build - Page 5 - Air Cooled 911s - PFA
Old 04-08-2018, 09:41 PM
