carfax discrepancy
How does a mileage discrepancy on Carfax affect the value on a low mileage 1988 930
Old 09-30-2018, 08:09 AM
Well is it truly low mileage? What is the mileage discrepancy? It may shed enough doubt on the credibility and legitimacy of the previous owner and what the odometer reads that it would be assumed to have much higher mileage
Old 09-30-2018, 08:37 AM
Pristine car. 30,000 miles. How does this affect the purchase price?
Old 09-30-2018, 08:55 AM
SalParadise's Avatar
It amazes me how these threads start with no information.
1) What is the current mileage of the car
2) What is the mileage stated on the carfax
3) What information do you have to doubt one or the other
4) Does the present owner present him/herself as truthful or is it a dealer?
5) And what the heck is the actual discrepancy? Are we talking tens of thousands of miles? or less than one thousand? As you know, these odometers are easy to change
That's all I have to say.
Old 09-30-2018, 09:25 AM
What kind of discreptency? You need to post more info! Is it just clerical error noted from a smog or repair station? Is it in big red letters saying “ODOMETER ROLLBACK” is it branded because of miles?
If it’s a simple clerical error you can email CARFAX , send them some records and within 2 weeks they will correct it usually.
CARFAX is a mafia , I pay $520 / month for that damn service, same as the rent on my office..ridiculous
Old 09-30-2018, 09:59 AM
RSS RSS is offline
How can you prove that an odometer rollback never happened and it was a clerical error while getting a smog check. That it what happened to one of my cars prior to me buying it and I would like to clear it up if possible. Thanks
Old 09-30-2018, 03:00 PM
#1 if its an obvious error, and if its simple it will NOT SAY "odometer rollback" i had a couple of those, recently a red 91C2 had 96,300 miles, then goes in for odometer and they put in 98,300 then next reading is 96,700 or something similar, so in that case, you email carfax , they start a case and you submit records to them from your mechanic or whatever and they will usually remove it.
Old 09-30-2018, 03:07 PM
speednme1's Avatar
Had this happen to me. A buddy of mine cleared it with Carfax rather quickly. He is a dealer and is signed up with Carfax. If it was during a smog check it can be cleared pretty quickly (since it seems to happen quite often) but if it was during an issuing of a new title then you would have to contact your DMV. PM me your vin and I will have my friend check for you( yes I talked to him about your subject ).
Rey....77 930 "the Mistress"
Old 09-30-2018, 05:57 PM
car is worthless, just send it to the crusher, worth scrap value now.
Old 09-30-2018, 07:02 PM
Former Options Trader !!!
There are a couple different things in play.
1) Is the error a simple fat finger error entered by a service provider?
2) Is the error an obvious fat finger error entered by a State agency?
3) Is the title branded as not original miles?
In the first case you can simply contact carfax and they'll typically make the correction by deleting the mileage on the fat fingered entry.
In the second case with a state agency, carfax will need to see a sequence of state registrations and / or docs from the state from before and after the date where the mileage is questionable. Its really a PITA although I have had success in having the carfax corrected in these cases.
In the third case, you're screwed. If a state has branded the title as TMU it will stay on the carfax. Its not all that hard to "wash" the title. States like Conn. don't issue titles for cars older than a certain age. I have heard its fairly easy to wash a title in Florida and Tx. too.
In the case of 1 or 2 I would not be overly concerned if it appears to be an obvious error. It will be a bit of a hassle to sell the car when the time comes. In the third case, let your conscience be your guide. I personally would steer clear of a branded title car even if the title was washed and it just shows up on carfax.
Carfax has plenty of flaws but understand the gen pop takes it as gospel and if you're selling a car with carfax issues, it wont matter how flawed you know carfax is the buyers are still going to look elsewhere.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono
Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S
Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster
Old 10-02-2018, 06:24 PM
RSS RSS is offline
I ran a carfax on my car a couple days ago. I have owned it for 12 years. Prior to me buying it there was a "Mileage Discrepency" of a couple hundred miles. I knew this had to be a clerical error so I contacted Carfax. They cleared it up in 2 days. Yah
Old 10-03-2018, 11:25 AM
If the obvious error was reported by a state agency its a lot harder than if the obvious error was reported by a service facility which worked on your car.
In the case of the service facility error, carfax will usually correct it without documentation as long as its very obvious and its not a significant discrepancy.
In the case of a state agency you would have to supply documentation as in a series of state inspections or smog reports from before and after the date of concern. Any other documentation you could provide including repair order from just prior or just after the questionable date is also helpful. It can be done, you just have to jump through a lot of hoops to get it done.
It helps if you have a relationship with a rep from Carfax. While I worked for Porsche I corrected many a carfax and I developed a professional relationship with my contact there. She was a very nice gal and easy to work with.
Old 10-03-2018, 12:16 PM
Amateur
pmax's Avatar
... which means any dealer worth his salt has a CARFOX fixer to correct any non official "discrepancies".
I don't need that.
Old 10-04-2018, 09:25 AM
I did it for years, there is nothing shady (the term fixer implies shady) about the process. Its quick and easy when you're a dealer who pays for carfax service. You have a log in to their system and you can submit everything right to their system. We moved about 100 used cars a month retail / wholesale and maybe I needed to have carfax fix 7 to 10 a year.
Old 10-04-2018, 09:28 AM
Amateur
pmax's Avatar
So, what the heck is not a real "discrepancy" ? 500 miles ? 2000 ?
I don't need that.
Old 10-04-2018, 10:31 AM
IMO when its an obvious error. Something like then the mileages are in ascending order for a long sequence, then there is one which does not fit the sequence, and then it goes back to the regular sequence.
Old 10-04-2018, 10:35 AM
Amateur
pmax's Avatar
I read that as any outlier in the otherwise ascending mileage sequence.
I don't need that.
Old 10-04-2018, 10:49 AM
