Porsche 911 Carrera 993 964 944 968 Cup Holder
Guys
I have 2 BRAND NEW AutoRacingTechnik Cup holder.
I sold my car, I dont need them anymore.
I just want to get what i paid. AUD$69 each + shipping
This is the description from them about this item
Classic Porsche Cup Holder
An essential that is lacking in your classic Porsche cabin.
AutoRacingTechnik supports the classics with this specially designed adjustable cup holder that attaches directly to your factory Porsche seat slide rail mounting points
Constructed from laser cut 4mm (approx 5/32”) corrosion resistant aluminium, with a waterjet cut natural rubber retainer to hold cups and drink cans securely, to prevent tilting and pitching when accelerating/braking/turning. Powder coated in satin black (uncoated aluminium finish available on request), it matches the interior, and looks period correct for your classic Porsche. Weighing just 170g it is lightweight and still robust enough to hold cups and drink cans/bottles up to 700g (over 1.5lbs). The removable cup holder arm is easily removed in seconds without tools and at 188mm compact enough to fit perfectly into your car’s glove box.
Unlike some other cup holders of similar seat rail mount design, which do not hold your cup or drink cans when your seat is adjusted forward. A driver who is under 175cm (5 foot 9inches) tall, will not be able to use some of our competitor’s cup holder. With our unique adjustable sweep angle, drivers of all heights are easily accommodated. Also, when taller bottles or cups are used, and could potentially contact the driver’s leg while driving, adjustable cup holder arm can easily be rotated to move cup out of the way. In addition, this feature means that when not being used, the cup holder can either be rotated out of the way, or separated from the mounting bracket and stowed safely away in the glove box of your 911/Carrera.
Symmetrical shape allows for fitting on either LHD or RHD vehicles, and on either driver or passenger seat, or both.
Features:-
· 170g lightweight and robust design
· Corrosion resistant aluminium construction
· Natural rubber retainer to hold cup to prevent tilting/pitching when vehicle is in motion
· Adjustable swing cup holder arm to allow repositioning and accommodate any driver
· Able to be fitted to either driver or passenger seat, in RHD bor LHD vehicles
· Powder coated in satin black to match your classic Porsche interior
· Tested to hold cups/drink cans/bottles up to 700g in weight
· 188mm removal cup holder arm easily removes in seconds and stowed away in 911/Carrera glove box
Proudly made in Australia
Suitable for
1974-1995 Porsche 911
1986- onward Porsche 944
The seat rail mounting bracket may require slight adjustment due to varying changes in the year of manufacture.
thank you
Old 05-05-2019, 02:21 AM
