-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/porsche-marketplace-discussion/)
-   -   Question on value - Rough car with lots of upgrades (http://forums.pelicanparts.com/porsche-marketplace-discussion/1032642-question-value-rough-car-lots-upgrades.html)
pampadori 06-19-2019 08:55 AM
Question on value - Ok'ish 1983 Targa with lots of upgrades
Looking for input on car's value. Chassis is potentially high mileage- ~300k TMU
Interior - a bit rough. Rear seats and side panel leather is dry and hard and sun bleached somewhat. Carpets are old and not great condition. Climate control features not 100%. Heat works but is backdated. Footwell blower inop. Front seats have been replaced with cloth Recaros. Steering wheel is a Momo Prototipo
Exterior - also a bit rough. Few dents, rear decklid gaps not even. Paint is good at 10' away but get close and you see some flaws. Has period correct Gemballa skirts and frt bumper. Targa top will soon receive full stg 4 rebuild.
Motor - lots of work in last few years. Recent rebuild with all bearings replaced, upgraded studs and rod bolts. Reliable, decent power, EFI with ITBs has never failed me since ditching CIS. Does have a couple of leaks at chain box/covers. Has desirable 930/52 case paired with 83 SC heads and all the common upgrades like tensioners and valve covers.
Very responsive - ITBs, EFI, alum pp, alum flywheel, 2.7 crank and rods, BBE heat exchangers, sport and race muffler both available.
bumpsteer kit, 930 tie rods, sticky Conti Sport Contact tires with like 90% left on them.
Basically, its a driver with lots of mods that is a blast to drive but not going to win any shows anytime soon. I feel like the motor and the driving experience are the highlights.
Here is a more comprehensive list of mods:
1983 Porsche 911SC Targa
Engine
9.3:1 pistons with Nikasil compatible rings from EBS
Nikasil lined cylinders EBS
930/52 case from ‘76 930
ARP Head studs
83 3.0 heads completely serviced in 2016 with .016” fly cut from standard
2.7 crank and rods polished and rebushed in 2016
Raceware rod bolts
911sc 3.0 cams
RSR rocker shaft seals
Triumph T595 ITBs and 28# injectors with aluminum fuel rails
PMO rainhats with K&N filters, custom made adapter plates w/ velocity stacks
AEM Infinity 506 ECU
Tomei FPR
BBE Heat exchangers
BBE 2 in, 1 out muffler AND Dynomax 17231 muffler with 2.5” piping
Carrera tensioners
930 lower valve covers
Fidanza Aluminum flywheel
Sachs Aluminum pressure plate
New oil lines from thermostat to motor and reservoir.
Suspension/Steering/Drivetrain
930 tie rods
Bilstein greens
Momo Prototipo
Wevo shift coupler
JWest Rennshift shifter
Bump steer kit (Steering rack spacers)
Refreshed 5th gear synchro, teeth, cage bearing at 71k (indicated)
Swepco 201 fluid
Body Wheels/Tires
Gemballa bumper and side skirts
H5 headlights
Continental Sport Contacts
16x7, 16x8 fuchs powder coated matte gunmetal
Recaro SPG seats
Rennline floor panels
Car Bone floor mats
Openable vent windows from early model
New windshield in 2018
Fire extinguisher with quick disconnect mount
Other
Rebuilt speedometer (Hollywood Speedo. Shows 72k but chassis likely has 300k+)
5th gear slider, synchro ring, dog gears all replaced along with fresh Swepco 201 in 2019
pampadori 06-19-2019 09:07 AM
http://forums.pelicanparts.com/uploa...1560963594.jpg
http://forums.pelicanparts.com/uploa...1560963663.jpg
http://forums.pelicanparts.com/uploa...1560963827.jpg
pampadori 06-19-2019 09:10 AM
http://forums.pelicanparts.com/uploa...1560964227.jpg
pmax 06-20-2019 03:40 PM
Cool targa w/good upgrades.
If selling, I would not call it "rough" in every paragraph of my description.
Matt Monson 06-20-2019 05:38 PM
I wouldn’t call it rough at all. Let buyers criticize it. No self deprecation in the ad. Just be open about it.
pampadori 06-21-2019 02:05 AM
Right. If actually listing the car, I wouldn't call it out quite the same way. However, I didn't want folks suggesting prices thinking it was in pristine condition so I emphasized that it has some "warts".
If the car was factory without the mods, I think I have an idea of what value would be. However, with the mods, which I think are inline with what a lot of folks would want to make for a reliable fun ride, I'm not really sure what asking price would be. I know you don't usually get back what you put in to a modified car but it sure would be nice to get close!
msort81 06-21-2019 03:38 AM
Love it ! Great looking car with all the right upgrades. Your buyer pool is small, so broaden it. I'd get some really good pics and put it on BAT. Otherwise i think you would get probably 50c on the dollar, especially with the current (stupid/misguided) trend for factory spec being highly desired. Yours is a drivers car for people who know what they should want from a Porsche, and that there is more to life than cleaning the car and driving it 25 miles a year to Cars a Coffee to pop the hood, hand out home made info sheets and bore stupid anyone who shows the slightest interest.
GLWTS
jhynesrockmtn 06-21-2019 12:31 PM
I love the car the way it sits. I expect it will be tough getting your investment back or close. I have a pretty heavily (mechanically) modded 83SC coupe. I bought it originally in 2007 or 8 from a guy who'd spent over $50k sourcing the car and then building it. It has a 3.2 motronic motor he had Chris Powell build with a nice parts list, added a Powell built 915 with LSD, Greg Forhdahl's shop massaged the suspension pretty heavily. The paint has some rough spots, it is gold and brown :-) which has grown on me, the interior is all there but the seats need redoing, headliner is bad and it needs carpet. I gave $22.5k for the car, sold it for about the same in 2012 and then bought it back two years ago for $27k which I thought was under market. If someone appreciates the mechanical setup you have I would guess mid $30k range? That's about what I would expect for mine.
quattrorunner 06-23-2019 05:18 PM
That case helps it.
It’s a good engine setup that’s fresh.
This car on bring a trailer should bring more than 30k if described right with good photos. And a good driving video.
Macroni 06-23-2019 05:36 PM
Great looking car.....
Bigtoe32067 07-02-2019 01:00 PM
I think the car looks sweet but I'm a sucker for a silver targa bar
Tony
