-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/porsche-marketplace-discussion/)
-   -   Price Drops Here there and Everywhere...It Has Begun in Earnest (http://forums.pelicanparts.com/porsche-marketplace-discussion/1044746-price-drops-here-there-everywhere-has-begun-earnest.html)
Matt Monson 11-19-2019 01:51 PM
Originally Posted by pmax (Post 10662944)
So did you ;)
A lesson, grasshopper. He may have me on ignore, but he still gets the PM notification that there is activity in his Japanese thread when I bump it. I'm the one who said Beetlejuice. ;)
dwelle 11-19-2019 02:42 PM
Originally Posted by Rawknees'Turbo (Post 10662833)
More bump! A lotta mo!!!
i got you.
So did you ;)
https://www.youtube.com/watch?v=L0MK7qz13bU
manbridge 74 11-19-2019 04:51 PM
Originally Posted by Matt Monson (Post 10662514)
As a high altitude dweller, I can tell you that CIS is more flexible than both carbs and MFI in various altitudes. One can take the car from “down” here at 5000’, up over Vail Pass at double that, and then drive on to down near sea level in Vegas with no retune or drive ability issues.
Not that Grady Clay was always correct in everything but his thoughts below from this thread, http://forums.pelicanparts.com/porsche-911-technical-forum/355853-mfi-altitude.html
“When correctly adjusted, MFI works great at altitude. Better than carburetors or CIS.
If CIS is adjusted correctly at altitude, it absolutely needs to be re-adjusted before any performance use at sea-level. The altitude correction is not as good as MFI.”
I didn’t mind CIS cars too much when I ran it but I kept them near stock. Last time I had the wide band hooked up I noticed the MFI compensated quite well on the daily commute from 6200 to 8500 feet. Unlike later DME cars where it is just a one time switch (at around 3000ft IIRC) the MFI aneroid is a sensitive linear device, adjusting mixture progressively.
911heaven 11-20-2019 03:27 AM
Originally Posted by pmax (Post 10662578)
Let's have a look.
First, what MM said ...
then given the caveman
... and half of the Bern vs amg show has already shown up ... you not seeing the signs ?
I'll write a poem for you Sean right now, albeit mixed with a little red Spanish Rioja. Goes like this -
AMG and me are free to be. I don bother him, he don bother me. If he tries to give me some, he won't have the chance to come. (I'll) Make sure of that at the drop of a hat. My bung is as tight as a snapper's ass, therein nothing can pass. Though you are a troll with a skinny wick, you love to take a solid dick. Blame it on yours and not our cars, for you are the troll behind the bars. Given a chance you may well see, this isn't the way it has to be.
Matt Monson 11-20-2019 03:51 AM
Bernie, you really need to quit with the anal sex references...
911heaven 11-20-2019 03:57 AM
Originally Posted by Rawknees'Turbo (Post 10662190)
Bernz, just to add a little to what IckyFicke and RawhideRey said about CIS (aka - Bosch K-Jetronic); pNutz is fond of the system because it is an old school (like his old ass!!!) injection system that performed well enough that it was on many European cars for decades (Porsche, Saab, Lamborghini, just to name a few, and hell, it was even on the snail slow Delorean with the Vulvo lawnmower engine). Also, that bisch pNutz has really studied the system over the past several years and is quite knowledgeable with regard to how it works, what the components are and do, and how to troubleshoot problems with it. Plus, Nutz is just weird like that!!! :D
CIS sux for several reasons, however. For one, it is entirely user untuneable in stock trim (except for idle AFR/CO level) - the only way for an owner to optimise the system is to have components re-engineered to be made adjustable. There are people that do this, but it is not cheap, and then learning to tune the system requires an onboard AFR meter and a lot of work and patience. Another suck is that even the slightest air leak anywhere in the intake tract (talking even a tiny, pNutz's d**k sized leak :eek:) means the engine will run like an old dog with chronic explosive, and dribbling, diarrhea, and then locating said leaks (often many all throughout the system) is a real chore. Related to that suck, the non-Turbo 911 variants utilize a complex airbox that is made of fookin plastic which splits wide open (aka - rendered useless) if there is an intake backfire (not uncommon during cold startup on the non-Turbo systems).
All of the aircooled Turbos ran CIS (except for the 993TT), so I am very familiar with the pain in the assery of it, and have gone to a lot of effort and $$$ to be able to properly tune the system (does not supply enough fuel during boost to support a better turbocharger than the weezy piece of shiit that the cars came with, runs borderline too lean at idle, and dumps too much fuel at boost onset). I've also become pretty good at troubleshooting it, unfortunately! I don't have actual hate for the system, but I have no love for it either, and definitely like poking fun at how long Porsche continued to use it on the Turbos.
And then you have Toby, who ditched his CIS for and even ruder and cruder fuel system - Caveman Carbs! :eek:
:D
Thanks Raw for that! A great tech surround and with optimum experience. I just got air cooled 101 educated and even got the gist on Toby's carb set reasoning vs the pmax passion for these. I'm learning. It helps a lot too since my acquired engine has the K-tronic old system. Still time on the shelf, yet I am brainstorming what to do. Still time on the shelf, yet time to plan. Engine still in Europe.
matt930s 11-20-2019 06:49 AM
second that
Vaive 11-20-2019 03:40 PM
Oh my!
20% and falling.
http://forums.pelicanparts.com/porsche-cars-sale/1037268-1990-911-c2-coupe-forest-green-metallic-green.html
Vaive 11-20-2019 03:45 PM
Poor feller, this has been here and Craigslist and who knows where else for months. Started out somewhere near $40K. I want to say $38-9?
Down to...$28K.
What cooling market you ask?
http://forums.pelicanparts.com/porsche-cars-sale/1041985-85-911-coupe.html
The funny thing is this guy probably got all sorts of "low ball" offers along the way. But he wasn't just going to give it away, amirite?
trader220 11-20-2019 04:11 PM
Originally Posted by Vaive (Post 10664279)
I sent the guy a pm he never even bothered to get back to me. It's a SALVAGE title so he wasn't realistic at the start. A lot closer now.
Matt Monson 11-20-2019 04:20 PM
Down to...$28K.
Dreamers gonna dream. A 200k mi car is a hard sell even when the market was frothy. But keep trying. Some day you might find a decent example.
manbridge 74 11-20-2019 04:48 PM
Vaive is often naive...
Macroni 11-20-2019 04:57 PM
Originally Posted by matt930s (Post 10663617)
second that
I agree.... dude this ain't that kind of site....
SkunkWorks 11-20-2019 05:06 PM
I have an original paint, unmolested, verified 86k miles, 3.2 915 coupe. Need to unload before market tanks further, $30k firm.
Macroni 11-20-2019 05:07 PM
Buddy of mine sold his 1994 w/ 116,000 for $69,000..... last month.
http://forums.pelicanparts.com/porsche-cars-sale/1037710-1994-964-c2-amazon-green.html
Vaive....Explanation?
speednme1 11-20-2019 06:08 PM
That Forest Green has a salvage title...so that may explain the asking price
Rawknees'Turbo 11-20-2019 08:24 PM
No problem, Burnz!
Are you sure that your engine has K-Jetronic, as I thought that Ruf Turbos were built with modified Motronic (early EFI system used on many Porsche models)? I'm no Ruf expert, however, so I could be wrong about that.
speednme1 11-20-2019 08:56 PM
Originally Posted by Rawknees'Turbo (Post 10664637)
No problem, Burnz!
Only RUF BTR3 had Motronic. Early BTR's were CIS
specialtyoneinc 11-20-2019 08:57 PM
Buyer didn’t get the memo
https://bringatrailer.com/listing/1984-porsche-911-carrera-42/
Rawknees'Turbo 11-20-2019 09:03 PM
Thanks, RawhideRey! :)
