Price Check on rebuilt 76 engine
I have acquired a rebuilt engine and honestly do not know the worth, but I'm thinking of selling. Any help would be greatly appreciated.
Specs: 76 7R case redone by Ollie's Heads redone by Ollie's and setup for twin plug ITBs, but missing the final fuel injection setup (quoted from Al Kosmal $2,420 to be running) All surrounding engine tin Shroud/Alt/Fan Exhuast back date and pre 76 heat exchangers So it would need a muffler and the remaining pieces from Al's kit to be a running drop-in distributorless/coil pack/twin plug engine |
What cams? What p&c set?
Matt!
I was hoping you would chime in. Cams are stock. P&C ill need to check. I want to say Mahle Nikasil. |
Not really sure what the point of twin plug is on stock cams. Would also need increased compression ratio. Rarely do people twin plug under 9.5:1, and usually it's higher, like 10+
