LinkBack | Thread Tools | Rate Thread |
77 2.7 Motor with upgrades - Honestly need help on Valuation, want to sell
Gentlemen, I am doing an LQ9 conversion so no longer need motor (motor is not damaged), 77, 2.7 was rebuilt 20 yrs ago with records - car was my weekend driver. Headers, Pop off Valve, chain tensioner upgrade, Permatune Ignition module /distributor electronic pickup upgrade. injector seals etc (all heat causing emissions features removed). I had always planned to do a LS conversion so after the CIS started acting up (running lean etc) I parked the car & started working on other projects ( I have 3 e30s). Now I want to move forward with my LS conversion and have been searching the web/ebay for similar engines to come up with pricing to no avail. As a long time member/customer since 1999 with Pelican, just want to come up with a decent honest price to sell the 2.7 motor. Can I please get some advice from my Pelican community? Thanks in Advance.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by rahtidone; 03-10-2022 at 12:33 PM.. |
Leak Down Test Results
Depends on whether it's a 911 or 911S, for port sizes. I'd pay $5K for it if it's the larger port engine. I view it as a core.
no difference in '77, they were all S's. large/small port pertains to the early/later SC motors, no?...
1971 914-6 GT 3.6 1974 911 1976 911S leaf green backdate 3.2 |
only small port 2.7 is a 74 normal non S, so yup large port 2.7
Roger that. I didn't bother to look up type numbers in 77! So... $5k.
Registered Minimalist
I also would say 5k on the high side. Exhaust and CIS is of little value imho. It has to be considered a core. I sold a similar long block for $2500 not too long ago without the intake or exhaust.
From a hot rod perspective the case, crank, and heads have value. I would put that value at 3-5k. Early T owners can use the crank in 2.2-2.4 engines. The 7R case is the best of the mag blocks too.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I missed it before... the 5 blade fan is a "lightweight" boat anchor! Seriously, a buyer will have to purchase another fan too.
Acquired Taste
if it was a 76 you could possibly get 2x as much. 76 is the cutoff for smog exempt cars in a number of western states and that is a huge factor.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Rosco_NZ
Is this ‘76 rule based on the car chassis number or engine serial number?? Can’t be both with engines & cars both being back and forward dated with engines ..
gearhead
Colorado is 75. I thought CA was too. Smog testing applies to the vin. Ain’t no smog tech checking the serial number on the engine unless something doesn’t look right.
One cannot put in an engine that is older than the vin/chassis. That’s a federal law. You can install something newer, and provide all smog equipment for that year, in states that test smog.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Matt, you are correct... 75 is the last year that smog testing is not required in CA.
2007 911 Turbo 6-speed, 1984 911 Carrera, 1974 911S, 75 914-6 conversion/project, 2007 Mercedes SL63 AMG, Coyote Powered FFR Cobra |
Hey man I’m interested in this motor. I PMd you, get back to me when you get a chance if you’re trying to sell it.
Tags |
77 2.7 pricing help |
