I am looking for someone who paints the Porsche crest onto the wheel center caps. Please advise - Frank
Do you know any hotrod or Harley guys? They'll know who the local pin-stripers are; that's where I'd start.
Mrs Weidman does an excellent job.
Richard 87 Targa 20 LS 500 |
I also have a question about painting Porsche center caps.
I've painted aluminum Porsche center caps using Testors brand enamel model paints (in the tiny jars), with very small brushes...followed by a clear coat. Works great...but the gold color of Testors is a bit too "neutral" (not bold/bright enough), and does not come close to matching the Porsche crest gold. So I'd like to repaint these caps with a palette which is a better match to actual Porsche colors. Any info. regarding resources would be appreciated. Thanks! |
It isn't hard to do. I started paint them back in the early 80's and tried marketing them but was told by Porsche to stop. Times have changed.
You can find gold paints that look proper at most hobby or arts and crafts stores even HD sells one that isn't bad.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS, Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others |
gearhead
If only we had a Tech forum…
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
