| Shuie |
03-05-2005 06:35 PM |
I pasted it into Word, did some formatting, and ran the spell check so I could read it. There is a lot of stuff that has been done to the car. Some of it sounds good (hotrod engine stuff from Jerry Woods and suspension setup from TRG) and some of it sounds not so impressive (cassette recorder)
here is a somewhat formatted version fo the ad
Please note this actually a RSR early, call it a replica in hopes of not getting into any legal issues with Porsche and I built it myself. Here are the write up.1972 911T modified specs to RSR for the road. Approximately 22,000 miles since restored, always garaged.
Body: All body work done by Conversion Techniques Inc., Oakland & myself
1. RSR body created by stripping car down to tub and doing complete body restoration. body straightness check on rack while stripped down.
2. Front fenders are original (73RSR), rear body fenders are part of complete new rear clips turbo body standard factory flares. Front and rear, valence and bumper are from (AIR) American International Racing fiber glass body parts (new)
3. Gas tank updated to 1979 SC with space saver spare. Stain less steel fuel lines used from tank to body.
4. Reconditioned battery bucket are like new (no corrosion).
5. Windshield washer bottle not installed but all parts available and working
6. H4 head lamps with extra bulbs, color matched covers for lens rims.
7. Side mirrors are all con vexed in original frame/casing. Special cut mirror by Cobel glass Inc., Oakland, CA
8. All factory body tags with serial#s are installing, driver side window frame, and driver’s door area on the body, in the trunk next to the gas tank on left side body.
9. All pedals have bronze bushings, gas pedal modified so both gas and brake at the same height by making the gas linkage longer. Left foot rest panel installed
Interior: All interior work done by Conversion Techniques Inc., Oakland & myself 1. All panels are like new.
(A). Door panels are new light weight panels with modified arm rests
(B). New head liner original lights, rear sides and back are reconditioned, dash is restored but not new, glove box is restored but not new, lock needs alignment to stay closed, 4, point roll bar, bolted in, no welding, with padding, (SCCA) legal setup, rear seat backs removed for safety and room, Sun visors are like new and work
(C). Stereo is Blaupunkt Bamberg with amp mounted on floor under passengers feet, multi band (LW,SW,AM,FM) and tape deck that will record cassettes, no CD this is a time period radio made 73 - 80. Needs the tape deck repaired I have location of a shop to repair and upgrade. Using windshield antenna so no external ant mounted. Some masking tape in some areas
(D) Seats are original Recaros in good condition, also have
One peace race seat that specially made up by my self for easy install and removal of four bolts, five point seat harness setup by Fry Racing, Milpitas, CA SCCA legal.
Suspension: Set up by Al Bauer’s and Racers Group
1. All light weight suspension parts from (79to 80 SC or Turbo) Turbo tie rods
2. Bump steer kit installed to keep the steering geometry straight.
3. All Teflon bushings
4. Shocks are Bilsteins Coil over, with sport shock inserts; no springs (coils) in us at this time due to upper shock mounts would need modifying.
5. 23mm and 28 mm torsion bars (race).
6. Factory Turbo sport sway bars front and rear (non adj.).
7. Cambertrust modified with Weltmiester for front shock tower bracing.
Tires/Wheels: Kahler workstate,Roger Krause Racing, Wheel Enhancment
1. (1) set of wheels, Kineses wheel three piece Carrera Cup 8" & 10" with BFG's KA 45 & 40 series tires for street.
(1) Set of factory Fuchs fronts 1 piece and rears 2 piece, 8" & 10" with Hoosier 50 series tires for track or auto cross.
Brakes: Al Bauers, Kahlers Werkstat & myself
1. Stainless steel lines with factory dual master cylinder.
2. Bremtek (4) piston calipers, with carbon pads.
3. (1) set of (4) cross drilled early rotors on car and (1) set of non drilled rotors (spares).
4. Front rotors set with cooling duct kits.
5. Wheel studs, 75mm (all 4 wheels) with 16.5mm front / 15.5mm rear spacers.
Engine: Kahler werkstat, Jerry Woods & myself, new at restoration, Euro Carrera 2.7 race engine, 276hp. less than 20,000 miles
1. Balanced pistons set
2. Race prepped heads, spring, and titanium retainers
3. Triad exhausts system (very light weight) and still has all smog points for test (lambda probe).
4. RSR factory set up muffler (replenumed 77 (2) in/ (2) out) made by Ralph at Al Bauer.
5. Chain tensioner oiling kit installed.
6. Intake given high butterfly affect with the us of 94 Turbo stand-offs, raising fuel injectors up from the intake valves, gives much better atomization of the intake mixture Air/Fuel
7. Permitune ignition.
Transmission: Al Bauers, Kahlers werkstat, new at restoration
1. New taller 5th gear.
2. RSR clutch with heavy duty spring.
3. Quaife, (torque sense. differential).
4. All new have shafts with repacked boot assembly.
Additional work:
1. Racer Group corner balanced for les than 3 lbs difference between wheels per axial
2. Suspension camber and toe set to standard race -2.3 degrees. This will wear out the street tires fairly fast.
