(the shotguns)
berettafan's Avatar
Rattlesnakes old car on Rennlist at $37k
I'm fairly certain it is Rattlesnakes old car. Rennlist classifieds, race cars, $37k. Just listed today!
If you buy it and live near Maryland you are hereby bound to take me for a ride in it!
Old 03-09-2007, 05:54 AM
DW SD's Avatar
I thought the car was brought to huntington beach area of California?
1971 RSR - interpretation
Old 03-09-2007, 06:39 AM
(the shotguns)
berettafan's Avatar
I believe the ad did say it was in Ca.
I was simply calling dibs on a quick spin if someone near Md. happened to buy it.
Old 03-09-2007, 06:40 AM
DW SD's Avatar
Gotcha! Post a link to the ad, if you would.
Doug
Old 03-09-2007, 06:49 AM
(the shotguns)
berettafan's Avatar
Category: Porsche Race/Track Cars Ad Number: 990
Price: $37,000 Date Posted: 03/09/2007
Expires On: 04/08/2007
Features
Year: 1972 Make: Porsche Model: 911T RSR Replica
Miles: Engine: Gasoline Stereo:
Body Style: coupe Transmission: Manual 5 speed
Color: Green Drivetrain: 2 Wheel Drive
Description
1972 Porsche 911T RSR Replica
This is a Street Legal Track Car with a 1995 993 3.6 liter engine and 2001 (Twin Turbo) brakes.
Exterior:
• 1972 911t Factory Non-sunroof Tub
• Full RSR Fiberglass Bodywork, Doors And Hood Are Steel
• Painted Factory Porsche Color, Gelb Green- PPG Imron (2005)
Engine:
• 1995 993 3.6 Engine / New Hlas
• Fresh 915 Gearbox / New Flywheel, Clutch, Syncros Etc
• Complete WEVO Shifter Set. –Shifter, Coupler And Gate Shift
• Magnaflow Exhaust W/heat
• K&N Cone Air Filter
Suspension/Brakes:
• 2001 996 Twin Turbo Complete Big Brake Set Up Front And Rear
• Tilton Brake Bias Adjustment Control
• Smart Racing Valved New Bilstein Shocks/Struts Front/Rear
• Front Monoballs
• Rear Adjustable Spring Plates With Poly Bushings
• Tarrett Front Triangle Strut Mount Bar
• 22mm Tarrett Engineering Front Through Body Sway Bar
• 22mm Tarrett Engineering Rear Sway Bar
• 23mm Front Torsion Bars
• 31mm Rear Torsion Bars
Wheels/Tires:
• CCW 17 X 9, 17 X 11 3-piece Wheels
• 245 and 315 Victoracer R Tires
Interior:
• Full Roll Cage
• Two New Corbeau Racing Seats
• G-force Cam Lock Harnesses.
• Complete Rennline Aluminum Pedal Set And Floor Boards
• RS Door Panels
• Momo Steering Wheel
• Radio Delete Panel
Other:
• Battery Moved To The Smugglers Box Via WEVO Kit
• Turbo Tie Rod Ends And Rack Spacers
• Brake Cooling Ducts
• Setrab Front/Center Oil Cooler w/ All New Braided Stainless Oil Lines.
• Mocal Oil Thermostat
• H4 Headlamps
• 13 Gallon Fuel Safe Cell
• Tie Down/tow hooks
• All Weather Stripping And Body Gaskets Are New
• New- Door Handles, Latches, Bearings Etc.
Located In Los Angeles CA With Current CA Plates. It Is In Excellent Shape. Turn Key And Ready For The Road Or Track. Has Attended Only Two DE Events.
Seller Information
Type of Seller: Private Seller Company:
Contact: Eric Williams
Manhattan Beach, CA 90266
Telephone:
E-mail: edesign45@mac.com
Web Site:
Old 03-09-2007, 06:59 AM
pwd72s's Avatar
Cheap! U ought to buy it Beretta...it's only money.
Old 03-09-2007, 08:08 AM
(the shotguns)
berettafan's Avatar
Honestly if i had the extra dough i'd be putting it into a non sunroof T bastard of some sort with narrow hips, PMO's, high compression and maybe an 'R' theme.
But it sure is a sweet car!
Old 03-09-2007, 08:40 AM
I'm still kicking myself for not pulling the trigger on that one!
Mike B.
'72 911E Coupe
Early "S" #1065
Old 03-10-2007, 04:51 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
I just saw this myself,.. !! That was definetly one of my better builds!
Marc
Old 03-13-2007, 08:25 PM
DW SD's Avatar
Does this car have an LSD?
Old 03-14-2007, 06:34 AM
