6 speed
Is it possible to fit a newer 6 speed to a 3.3 turbo. If so what would all be involved.
6 speed
Somebody has got to know.
Uh. Try asking on a technical forum appropriate to the question.
Anything is possible, given deep enough pockets, creativity and desire. Why bother? A correctly-built 3.3 turbo is a torque monster and doesn't need 6 speeds. Time spent shifting is time out of the throttle. If you've built a un-streetable 930 with an insane amount of boost capability, little or no off-boost power and a very tight power band, it's likely in a lightweight tube framed car anyway (and should likely be making upwards of 800-900HP). In a tube framed car there would be little difficulty in making any gearbox you want fit. There are a number of examples of street-registered and driven 600, 700+ HP unibodied cars running a 5 speed. Quote:
The long bell housing G50 is longer by about 1.5-2" and requires moving the motor back, which increases the weight bias to the rear - not ideal. Most people shorten the bell housing and the shafts instead. Torsion bar tubes probably still need to be reinforced/modified to clear the longer end cap. This is expensive to have done by a shop. The 6 speed is longer still - that extra gear lives in the end housing - and not by a small amount. I think it's even a long bell housing, just to make it more interesting. That's a lot to move the motor back (there's not that sort of room before the rear cross member). The only other option is to recess the end cap into the body, and retain something resembling the stock mounts.
'77 S with '78 930 power and a few other things. |
Former Options Trader !!!
The simple answer is yes you could do it with enough money or skill, but no its not a straight swap.
Current:88 Guards Red Coupe, 89 Coupe Track Rat, 76 Caddy Eldo Convert. 2015 Aprilia Tuono Wrecked 1987 Targa Guards Red, 2003 Ducati ST4S Sold 1987 Granite Green Targa, 993's, 93 RSA, other 964 coupes, 89 911 Turbo Ruf mods, 90 e30 M3, 07 BMW R1200S STOLEN 94 Speedster |
What year 3.3 ? If its 89,91 it could be as easy as bolt right up..
I'm installing a G50/52 (Euro 6sp/LSD) in my '91 and it's straight forward. If your considering an earlier swap you have the standard space constraints and hydraulic lines and associated components to overcome..
GT2 RS 3.2 RSCS 3.8 R 2.5 Twin Plug |
