Sum of the parts worth more than the whole?
I appreciate all the information on this site and need advice.
I've got a 77 targa that drives very well but has rust and oil leaks. My question is: Is it worth more in parts than it is as a whole. I already know It's not worth the cost to repair the rust and I don't want to just cover it up to sell the car. ![]() More pictures can be seen at Targa pictures by 3stewarts - Photobucket |
A little bit of rust? Completely rotted?
Oil leaks are a smaller concern compared to rust and many are an easy fix. It looks to be fairly stock and original which is good. The rust in the rockers is not good but the rest of the car didn't seem that bad at all.
Kurt Last edited by KNS; 06-15-2011 at 12:23 PM.. |
Yeah, the oil leaks can be fixed in a weekend.
![]() ![]() The rust could take a little longer |
Parts will bring higher return..... Motor alone could go for 3k.... Targa top etc...... Wheels.....
The car, an unloved middie, will be worth under $ten as is... It probably deserves to live........
63 356 2.1 Rally Coupe 75 911M 2.7 MFI 86 Sports Purpose Carrera "O4" 19 991.2 S Last edited by Macroni; 06-16-2011 at 01:47 AM.. |
That rust looks bad. I would check under the battery and that area. I know a guy who did the correct repair for that area to a 77 himself, and he said it was an nightmare and he wouldn't do it again (not to mention it is a grand just for the replacement panel).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off. 2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver) |
Part it.
John- 78 Slick Top 930 "Illegitimi non carborundum" |
