-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/porsche-marketplace-discussion/)
-   -   Convert from 2.7 to 3.2 how difficult? (http://forums.pelicanparts.com/porsche-marketplace-discussion/711192-convert-2-7-3-2-how-difficult.html)
brock911 10-13-2012 04:37 AM
I would like to know how difficult it would be to swap a 2.7 for a 3.2?
I'm considering the purchase of a 74 with the 2.7 (CIS converted to carbs?)
Has anyone experience with this and can offer an opinion?
Should I even consider doing it, are there any advantages to keeping the 2.7 with a Zenith carb set-up? I have heard stories of heat affecting various metal components and head studs pulling etc etc etc?
Thanks for any input,
Stay well
Mike
E Sully 10-13-2012 06:46 AM
I've done it with my 1973.5 It was not that difficult. 3.2 is a great engine, and Motronic was a lot simpler to set up than the cis. There are a few issues with the 3.2 engine. They used the dilavar studs which can break, and ususaly will need the original valve guides replaced. Transmission issues are minor, notches would need to be cut in the housing to clear the flywheel sensors on the 3.2.
1973 Porsche 911 - YouTube
brock911 10-13-2012 11:23 AM
Thank you Ed,
Mike
techweenie 10-15-2012 09:57 AM
You need to drill a hole in the area at the extreme left bottom of the rear seat vertical base near the pan to run the control harness to the ECU, which sits under the driver's seat. There's also a little work needed to adapt the 14-pin engine compartment connector in your current chassis to the 3.2 engine harness.
Todd Simpson 10-15-2012 04:20 PM
A 3.2 swap is fairly easy, and well documented.
You might want to post some details on the car though...a lot of these "mid year" cars were neglected and you are often better off buying an SC or Carrera, even with higher mileage.
John80 10-17-2012 11:18 PM
Thanks for the Info
