78' SC Keep it or sell it? Values?
Purchased without a PPI....:mad: Struggling with this. Back in 5/04 @114k car had a full body restoration with a few mechanical upgrades. Repainted with a '03 Lapis blue.
New body items: Re-paint All new rubbers for glass Rear tail lights Hood shocks/rubber Rear deck-lid Dual shock kit Headliner Sunroof seal Engine: Carrera tensioner update kit Pop-off valve Euro muffler cat-bypass (Fabtech) Oil temp gauge to degrees New plugs / Cap / Rotor Suspension: Bilstein Shocks New sway bar bushings New rotors New pads Rebuilt calipers Stainless flex hoses 10/14 @117K Had a very reputable Porsche mechanic perform a PPI for me before I listed it. Everything checks out except. Poor leak-down numbers on 2 cylinders. Further inspection is pointing towards a top end rebuild. Do I drop the $$$$ and rebuild or sell it as is. http://forums.pelicanparts.com/uploa...1414087388.jpg http://forums.pelicanparts.com/uploa...1414087416.jpg http://forums.pelicanparts.com/uploa...1414087468.jpg http://forums.pelicanparts.com/uploa...1414087522.jpg http://forums.pelicanparts.com/uploa...1414087556.jpg http://forums.pelicanparts.com/uploa...1414087617.jpg http://forums.pelicanparts.com/uploa...1414087648.jpghttp://forums.pelicanparts.com/uploa...1414087879.jpg http://forums.pelicanparts.com/uploa...1414087964.jpg |
I guess the question becomes why do you want to sell it?
Personally I would keep it and rebuild it. But this is really personal, so back to my question. |
If you're gonna sell it I would say sell as is. You will not recoup top end job cost . May be easier to sell with rebuild but I doubt you will see more than 50% of your cost.
Pretty car but do I read correct you've only driven it 3000 miles in 10 years? |
+1 Rebuild and keep. This looks like a really nice car.
Frankly, someone will beat you up on your price knowing the car needs a rebuild and I doubt you'll get your money out of it if you decide to rebuild and sell it right away. With the prices going they way they are going on air-cooled 911s, I think time is on your side unless you have to sell it for personal reasons. It doesn't appear you drive the car much... maybe it just needs an Italian tune and some hard miles to help the #2 compression. This link may help. http://forums.pelicanparts.com/porsche-911-technical-forum/266919-1987-carrera-failed-compression-test.html |
Value??
#'s for these cars are crazy.:eek: I'm leaning toward the rebuild. In the event that I do sell it, the next person would have a true turn key Porsche SC that could be enjoyed and driven. As-is 15-18k? Rebuilt 20k?
All info greatly appreciated. Toby |
Rebuild will likely set you back 10-12k...
My guess says more like max 12K as-is... and more like 25-30K rebuilt...but what the frog do I know. |
If you've lost interest, sell it. Advertise it for a month as-is and if it doesn't sell, get it rebuilt over the winter and sell it in the spring.
I think you can get around $15k as-is |
How bad is leak down on no 2? How does it run...smooth....pulls good?
It's been driven so little and likely lugged around. Before I would go rebuild I'd put some good gas in it with tech ron additive or the like and drive the snot out of it for the entire tank. Then take it to another shop for a comparison leakdown. You may be pleasantly suprised with the carbon build up blown out. Put a new aet of quality tires on to replace the 12 year hockey pucks. Then ask $28k for it. But you may have enough fun driving it as intended you may keep it :D |
#'s on Comp & Leak-down 155\6 135\10 150\18 125\42 135\8 135\16 I suspect maybe head studs? Tires are a bit old even with less than 2,000mi on them |
The puff wouldn't concern me. No smoke on deceleration? Did John Walker do the ppi?
Yes on JW. No smoke other than right at startup which I understand is common.
Thanks guys on your input
Don't post very often as most of my questions are answered by a quick search. |
I would keep the car and rebuild the engine.
You've done so much work already so you might as well finish the job. Looks like you have 3 cylinders that need attention. Anything over 10% leak down smells like a rebuild is around the corner. 42% is a really big number.......:eek: 155\6 135\10 150\18 125\42 135\8 135\16 |
Sell it and let someone else do the rebuild.
I would love to have a project like this. Please PM me if you decide to sell.
Maybe there is a lot of carbon, and that is causing the poor leakdown numbers? Or head studs. |
| All times are GMT -8. The time now is 08:55 PM. |
