Troll Hunter
Value effect of rebuilding an original engine
There's a longhood that's got a matching numbers 2.4 in it that needs a rebuild. Of course we're looking at the many upgrading alternatives, as I've posted in the Engine Forum.
But what does the collective think of the effect on value when you do any of the engine upgrades available, like those described in Wayne's book, or even upgrading to RS Spec? Some say it's a desirable upgrade, and helps. Others say the car is no longer original, even though it retains the same engine, just modified.
Opinions?
Thanks!
Nick
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 01-06-2016, 05:12 AM
Topless crazy
seanratpel's Avatar
Remember - they are only original once. regardless of changes big or small!
Old 01-06-2016, 05:15 AM
body is going to stay original ?
if it looks and sounds like the original motor then no one will know if you made it more CCs , they will just think it is a strong running motor
if you change too much external stuff then it is almost as bad as changing motors since the average guy will not be able to put it back to the original look..
looking for information about old VW Coach built based sports cars, or photos and stories from the past ,
At one time many of these got confused as "Porsche prototypes" including the one restored at Hill and Vaughn in Santa Monica
Old 01-06-2016, 05:37 AM
blau911's Avatar
Nick, others will disagree, but I am of the opinion that as long as the car uses the same matching number engine, the same displacement, the same fuel delivery system and same engine wiring, all internal specs of the engine can be changed with no negative effect on value. In fact, rebuilding a 2.4T MFI motor to higher compression S or RS spec is a plus in value - as long as it was done by a reputable shop with paperwork to confirm what was done. A nice running 2.4T is a good engine, but a 2.4E, 2.4S or 2.7RS is even better....
Old 01-06-2016, 05:40 AM
Platinum Member
dad911's Avatar
Instead of spending the money on a rebuild, I'd put the 2.4 on a shelf for the future, and drop in a 3.0 or 3.2.
Old 01-06-2016, 06:30 AM
Troll Hunter
Great input so far. Keep it coming.
If these cars were meant to be completely original forever, we'd all have them locked up in a nitrogen bubble somewhere.
I personally think a original, rebuilt engine to higher specs is a plus...but that's just me, and why I'm asking you guys.
I've weighed the replacement engine alternative. Even Wayne talks about it in his book. The cost of a replacement engine, that's in good or rebuilt shape, will be more than rebuilding the 2.4. Of course, you now have TWO engines, and one still needs a rebuild.
Pretty pricey alternative IMO.
More input?
Thx
Nick
1988 FJ62 Blue/Gray
2020 M2 CS
Old 01-06-2016, 08:28 AM
Home of the Whopper
That's sorta what I would do, but I would want a nice higher compression 2.4E instead of a 3.0 or 3.2.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 01-06-2016, 08:36 AM
Originally Posted by blau911 View Post
nick, others will disagree, but i am of the opinion that as long as the car uses the same matching number engine, the same displacement, the same fuel delivery system and same engine wiring, all internal specs of the engine can be changed with no negative effect on value. In fact, rebuilding a 2.4t mfi motor to higher compression s or rs spec is a plus in value - as long as it was done by a reputable shop with paperwork to confirm what was done. A nice running 2.4t is a good engine, but a 2.4e, 2.4s or 2.7rs is even better....
+1.
Old 01-06-2016, 08:43 AM
gearhead
If it were me I wouldn't go all the way to the 2.7. I would personally stay away from modifying the case for the bigger displacement. If it were mine, I would build it as a 2.5l with 1mm overbore on the cylinders and some JE pistons. Single plug. Low 9's compression with a Solex ground cam.
And just keep all the original parts in boxes on the shelf for if you ever sell the car. You never know what the next guy will want to do with it, unless you plan to make the car your coffin when you check out.
To answer the root question, I think what I suggest is a zero sum game for end value. I think if you modify the case you will devalue the car in the eyes of certain potential buyers. But it's a very personal question. I am reminded of the discussion we had last summer about inoperable AC. For a sizeable group of people the AC not working is a big hit on the car and they wouldn't even contact the seller unless they felt the car was already discounted. For others, it meant nothing because they would rip it out anyway. Engine mods become like the same sort of thing.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-06-2016, 08:46 AM
Agreed if its a period modification with real parts then it adds value. Similar to a 3.4 Mahle upgrade on a 3.2 Carrera.
Old 01-06-2016, 08:53 AM
gearhead
To this point, Steve at Rennsport Systems can still get original Mahle 2.7RS P&C kits. If the the 2.7 was done, I would use those parts over Nickies and JEs.
1974 914 Bumble Bee
2009 Outback XT
Old 01-06-2016, 09:03 AM
