-   Porsche Marketplace Discussion (http://forums.pelicanparts.com/porsche-marketplace-discussion/)
-   -   SC extended front pan value? (http://forums.pelicanparts.com/porsche-marketplace-discussion/916347-sc-extended-front-pan-value.html)
Puma 05-31-2016 08:44 AM
I may just buy correct '68 pan parts for my car so I might sell this but have no clue as to the value. Any idea?http://forums.pelicanparts.com/uploa...1464713085.jpg
Matt Monson 05-31-2016 08:48 AM
Restoration Design's replacement version runs $200 new. Some may value original factory sheetmetal a little higher. Others won't consider it worth any more than the replica parts.
Regards,
Matt
MattTHEpainter 05-31-2016 08:57 AM
That looks like an aftermarket front pan, correct?
Puma 05-31-2016 10:09 AM
I'm not certain if it's aftermarket or not. There's a sticker but I can't read it.
Thanks for the info.
Matt Monson 05-31-2016 10:20 AM
I'm no sheetmetal expert, but if there's a sticker it is likely aftermarket. Original factory sheet metal was primered in a sort of greenish primer.
tholyoak 05-31-2016 12:21 PM
Likely like a Dansk pan.
http://forums.pelicanparts.com/uploa...1464725957.png
Should work perfectly fine for your car, just weld on the tow hook and use the correct gas tank support/battery tray from restoration design
Puma 05-31-2016 01:40 PM
I think what you're suggesting would be the best/ easiest route. Thanks.
