Weber 40 for Porsche 911
Gents.
Have this set - bought a long time ago - never tried them on. ![]() ![]() ![]() ![]() ![]() ![]() I think it´s all there - and it should be assessed as cores. Can anybody id the year for these.? and they value.? Thanks - Cheers - Tommy.
“I will not demonstrate it, I will race it.” Juan Manuel Fangio |
Right below the Weber on the carbs are some stamped numbers you'll need to post to get an idea of the model of carb. There is also a casting date on the side of the manifolds. It'll be a 66, 67 ,68 or 69 with a bunch of dots around it that indicate the month. Post those and a more definitive answer can be given.
Weber 40 - Porsche 911
Thanks.
Here is what i belive is the Numbers on the Webers. ![]() First: 40IDT3C Second: 1735 ![]() It says: 68 ![]() First: 40IDT3C1 Second: 1979 ![]() It says: 68 Let me know what you guys Think.? Thanks - Cheers - Tommy
IDT's are lower in the triple Weber 40 totem pole.
Current: 914/6 GT Conversion, Cayman Old: Many PCars + Formula Racecars |
yes, there were three Weber triple throats put on two liter 911's. IDT, IDA, and IDS. IDT's are the least desirable and IDS are the most desirable. The IDT were put on the detuned 2.0 911T, the IDA were put on the standard 911, and the IDS were put on the '67 and '68 911S.
webers Porsche
Thanks.
What would the value be of these IDT.? Thanks - Cheers - Tommy.
As a complete setup with air cleaner and crossbar I would say in the neighborhood of 2K plus or minus a few hundred. IDA's I'm more familiar with and those generally go for around 2.5K plus or minus as a complete setup.
gearhead
IDT's are from a '68T. I would agree $2k or less.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
gearhead
Here's a comp on just the carbs themselves.
FS Weber IDT Carbs
