Another value question on a 76 Carrera engine
Hi,I have an early 76 Carrera 3.0 engine serial # 6660002.930/02 on the case.I also have 6660003 as well.One more question is I have a 76 3.0 with serial # AT6660190.What does the AT in front of the serial # mean.Maybe it is a job for the Tech Weenie.What is the value on the low case serial #.I always thought the first 10 numbers were for testing purposes.Come on Pelicaners enlighten me.Thanks Fred
Pretty sure that means factory replacement.
AT stands for AusTausch as far as I know. Factory replacement indeed.
Erik |
AT meaning
Hi,thanks for your input on the AT prefix.I knew you would enlighten me.You guys are the best.Thanks Fred
