wannaporsche
2006 Cayman S IMS
Soooo tempted to grab this car.... am getting snagged on the IMS Issue. Anyone know a reasonably ($) good permanent fix for 2006's IMS?? Is bearing concern an overhyped and non-real source of worry??
2006 Porsche Cayman S
________________________ Tim 1980 SC Sunroof Coupe 2006 A4 Quattro 6 spd manual |
Administrator
+1 on the PPI. If needing an IMS kit, look at LN Engineering - excellent quality parts.
gearhead
Doesn’t have an ims in the way an m96 does. Non issue imo. My car had 175k mi on it when a valve spring broke. On tear down the bottom end looked like new.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Not a smoking deal for Cayman S based on what I sold my '08 for a year and a half ago. It is a hell of a good bang for the buck as compared to an air cooled though. I believe that era of engine requires the case to be split to change the IMS bearing. No one does that due to the expense. Check the water cooled forums but I believe the failure rates in the '06 models was higher than the '07/08.
__________________________ '18 Macan S - my turbo Porsche previous Pcars '58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E Last edited by mattC2993; 12-22-2017 at 03:16 PM.. |
Back when I was big into Autocross, there were 3 or 4 '06 Caymans and all of them had catastrophic engine failure. I believe Porsche replaced all of the engines which were at the time still under warranty but I wouldn't buy any pre 2009 Cayman or Boxster or 996 or 997 for that matter without going into it knowing an expensive engine repair or replacement was always a possibility. Granted I only dealt with m96/m97 motors that saw HARD use but I can only think of a couple that wore out before some sort of catastrophic failure on something that I normally wouldn't consider a traditional wear item. A friend with a Boxster Spec race car went through 8 motors before having enough and moving to another platform.
Bore scoring seems to be more common on that era Cayman S than IMS issues.
Kurt |
gearhead
The independent Porsche shop owner in San Diego I go to once in a while told me that they never see Caymans with IMS issues. But there was a Boxster in front of the shop with a blown motor caused by the IMS. He said that Cayman owners should not worry.
My friend picked up a 2008 Cayman S with 60,000 miles last spring. All the service records were up to date and it passed the PPI with flying colors.
5,000 miles later it was making a strange noise and the oil light illuminated. Ended up being a failed rod bearing. $18,000 later it is back on the road and it is now a keeper. From reading threads on Planet 9, it seems like the base models have the least engine problems or failures.
John D. 82 911 SC Targa-Rosewood 2012 Golf TDI |
I think it depends on your use. Want to do some HPDE and heavy autocross with mods to the suspension....be ready to change the motor. Just drive it around on the street? probably not high probability of a failure.
Although I have seen plenty of stories of folks that track the snot out of M97s with no issues....
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
wannaporsche
Spoke with seller - there's a bit more to the story. This car - which was a very early delivery 1st edition 'Launch Code' car - actually blew it's original motor at about 30k while under warranty. Porsche replaced that motor with another new 2006 S engine. No certainty, but the seller's theory is that the 1st motor was a M96, and the new one is a M97. In any case it looks like at least some Cayman S's do blow - or least this one did.
I've been considering a 987.1 CS too, but it's the scored bores and oil starvation that concern me. Probably fine on the street, but I hate the idea of motor failure and the $$$ to repair. That would probably be lingering at the back of my mind on every hard drive. It seems the bump in price to a 987.2 is worth it for the peace of mind (and considering the $18K price quote above for a rebuild). It's just very hard to find a 987.2 CS nationally, let alone locally.
gearhead
2009 Base is the best buy imo. It’s a great little engine without the drive and if you aren’t building a track beast plenty of power. It’s what I would have bought if I didn’t need an early gearbox for my prototyping.
Matt, are we talking as a daily driver or something for weekend hoonage on the back roads? I’m in the latter usage and I do wonder if a base 987.2 would give as many giggles as the 3.4. People say you just need to work the 2.9 a bit harder. That seems entirely compatible with weekend driving to me. Also, the 2.9 has improved oiling for the occasional track day, correct?
Sent from my iPhone using Tapatalk |
gearhead
gearhead
Great color. Wonder why it was sold just 3 months after purchase. Still seems well bought on the surface.
1986 Carrera coupe - black on black 1972 CB500/4 |
Finding a 987.2 Cayman is challenging! Any thoughts on the 987.1 base Cayman (2.7)? I've heard they are less prone to bore-scoring than the 3.4 and a lot of folks really seem to rate them for fast road use since you get to explore more of the rev range than the 3.4 without doing silly speeds. I guess they still suffer from the same oil starvation mode as the 3.4 though...
