Why so cheap?
Why are the earlier - 1977 2.7 liter 911’s so cheap?
Have a chance to get a repainted ‘rare’ blue 1977 with 30k miles on rebuild and no rust for about $25k
There is a yellow one that was also posted in seattle Craigslist yesterday for $25k
What makes these the least desirable?
Old 05-17-2018, 08:47 PM
Kind of Blue
MrBonus's Avatar
They utilized thermal reactors for emission control which tended to cause the engines to run substantially hotter and warp the heads over time. The "mid-years" were considered the stepchild of the air-cooled 911s for years as a result.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel)
2024 Ford Bronco Raptor
Old 05-18-2018, 06:01 AM
Here we go again...
Old 05-18-2018, 06:05 AM
non-whiner
mreid's Avatar
The 2.7 with the stock exhaust removed and an appropriate aftermarket installed, Carrera tensioner, etc. is a reving monster. While light on HP, they are a blast to drive. Many still see them as underpowered impact bumpers, where the SCs and Carreras are better. I disagree as long as you are willing to make a few improvements.
"Too much is just enough."
Old 05-18-2018, 06:08 AM
Longtime Member
juanbenae's Avatar
most of the states that require emissions testing, CA & CO come to mind off the top of my head still require testing on the 76 & 77 models so they are less desirable for the items noted above.
Old 05-18-2018, 06:25 AM
Ahh okay I've heard people skim the subject but no concrete answers. Thank you!
I've got a chance to get a 1977 911S for $25k
Has 125k on body, and 30k on engine rebuild.
No rust and had bare metal repaint to original paint code 304 (caribe or manerva blue?)
Only issue is cracked dash and a window switch needs rewired.
Thinking about pulling the trigger. Let me know if any interest in pics.
Old 05-18-2018, 10:37 AM
non-whiner
mreid's Avatar
You don’t know us very well. We are ALWAYS interested in pictures!
Old 05-18-2018, 10:42 AM
thamlin000's Avatar
All smog strangled 75-77 2.7s needed their engines rebuild between 60-90k mi. They are good with the following updates:
-pulled head stud issue fixed.
-no thermal reactors
-add SSI
-add sport exhaust
-add pressure fed carrera chain tensioners
-pop off valve
-11 blade fan, not the 5 blade.
Everyone talks about originality is valuable in all air-cooled 911s. Not true with the 75-77. Nobody wants one with thermal reactors, stock exhaust and 5 blade fan. All my listed mechanical upgrades add to the value.
The present: 83 944, 77 911S
The past: 95 911, 67 912, 76 912E
Old 05-18-2018, 10:50 AM
Flynt's Avatar
Post pics and contact info. I'm going to buy it while you're thinking.
Old 05-18-2018, 11:00 AM
GothingNC's Avatar
Wow, I passed on a 77 911 Coupe in green with only 45,000 miles in excellent condition that had recent top-end rebuild for pulled head studs back in 2006.
Asking price was $14K and I thought it was too high at the time and picked up my 82 Targa a few months later for a little bit more.
Took the seller about 2 years to find a buyer.
John D.
82 911 SC Targa-Rosewood
2012 Golf TDI
Old 05-18-2018, 11:16 AM
non-whiner
mreid's Avatar
Yeah, well I also sold a 1986 930 with 42k miles for $34k six years ago. I try not to think about it. At least I know it went to a great home!
Old 05-18-2018, 11:33 AM
gearhead
2006 is a lifetime ago in this market. Even 76-77 cars rarely go below $25k these days.
If I were in the market, I would be kicking the tires on Ficke's 77 Targa in the classifieds. I think that's a nice car and the money on it is right, $32k.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-18-2018, 11:35 AM
Old 05-18-2018, 11:36 AM
-add SSI
-add sport exhaust
-pop off valve
Appreciate this man!!!
Asked the seller if any of this was done.
Now I feel even more pissed the local guy to me sold his 77 911S with a 3.0 in it and an added well-done SC wide body... Oh well.
If you guys wana get even more upset google some older 2008-20012 for sale ads LOL
Old 05-18-2018, 11:53 AM
thamlin000's Avatar
Sold my 67 912 golf blue (all original body and interior, even radio) with an engine by Harry Pellow (The Maestro) for around $6k in 06. Sold my 95 993 coupe with 110k mi for $21k in 08. Bought a 912E for $6.7k in 2011. Back then, good SCs were $15k. 964s were under $20k.
I thought I'd be getting different flavors of air cooled 911s for $20k forever. Maybe even splurge for a $30k-$35k 930. Everything changed for the worse around 2012-13.
In '15, I bought my 93k mi 77 911S coupe for $25k.
Old 05-18-2018, 12:27 PM
Stay focused guys. What about the same color 1976 912 with 125k original miles and original motor/trans?
They also have these issues? Have chance to get one at $20k
Let me know it’s the same color as the one above! Weird
Old 05-18-2018, 02:01 PM
Send a message via Yahoo to rgofast
A few years ago no one wanted the mid year cars. They are all that is left that’s affordable. Not many left as a lot of them were junked out, because of the previous low valuation. As far as the engine goes, the main problem was the twisting cases, not warped heads. Yes the exhaust valve guides failed very quickly, but not the entire head. The thermal reactor cars ran very hot in order to pass smog. Most of these cases not only pulled studs, but the cases really deformed. Most likely would need to be line board, and have the spigots re surfaced, along with inserts and steel studs. If you build them right, and don’t over heat them, the 2.7 is a very nice engine, and much lighter than the aluminum alloy engines.
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke
1973 1/2 911T S optioned sunroof coupe (in progress)
1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels
1999 996 Carrera Cabriolet
Old 05-18-2018, 03:03 PM
Sheesh.. I have a long way to go with porsche knowledge
Old 05-18-2018, 04:55 PM
gearhead
It's basically a 914 engine. Different beast.
1974 914 Bumble Bee
2009 Outback XT
Old 05-18-2018, 05:13 PM
The blue 911 is nice. That wing will not look good in person on a narrow body though. Get the car and remove the wing.
Old 05-18-2018, 05:57 PM
