Jack Help! (Urgent)
Is this the right place to use a jackstand in the front???|
Yes. Jim sims
Thanks, Jim!
You guys are the best. I didn't want to leave it there if it was insecure, as it will be up there for a week or so. |
Is that the front of the A arm or the back outside edge?
'60 356 Roadster Race Car '67 911S Race Car PRC Toyo Spec 911 Race Car |
The front, right next to the A/C evaperator or whatever that grill thing is under the bumper.
This is safe with 4 stands for a week or so, right? |
It good for an indefinite period of time provided the back jack stands are on the rear torsion bar ends. Jim
The rear was easy, I had problems getting the jack stands under the tbar tube ends. The front was a different story..... It is really low, and there is no easy way to jack it up and put the stand under the same point. I had to get creative with a few 2X4's under the tire.
Thanks again to everyone, I feel better that it won't collapse over night! (or over the next week)
I was told the best spot in the front end of the car was at the "bend" behind the front wheels where three layers of sheet metal meet.
Harry 1970 VW Sunroof Bus - "The Magic Bus" 1971 Jaguar XKE 2+2 V12 Coupe - {insert name here} 1973.5 911T Targa - "Smokey" 2020 MB E350 4Matic |
Thanks, ruf. I knew it was part of the A/C system. I could probably remove it, anyway, since my A/C stopped wrking about a year ago. The funny thing was, it stopped just a few days after I removed the compressor.... Coincidence? I think not!
'83 SC Coupe- Blk/Blk '03 Daughter- 10fingers/10toes |
It ran for a couple of days without a compressor?!
Ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
No, I was kidding.
911 + 129 = JOB
Right behind the front wheel well in the corner is a small square section underneight that the 911 manual tells you to use it to lift the car.
I am unable to get a jack under my front end, but I can get it to this spot. IS it safe to lift the car at that point?? (I have done it, but want to make sure its safe)
1989 911 Carrera Coupe 3.2 2012 BMW 135i M Sport "It is not how much power you have, it is how much you have left to spare!" |
Magilla,
Don't worry about me, I was trying to be funny too! Ryan
I wish someone would take a photo of the underside of the car, circle the jack & jack stand points (using Photoshop), and post it on a permanent web page....
Semper drive!
This "square section", are you talking about the area about 5" x 5" in the front corners of the floor pan...just aft and inboard of the front tires?
I believe I've located this area, just want to be sure. Don't want to end up wearing my p-car as a hat. ![]() Randy
84 944 - Alpine White 86 Carrera Targa - Guards Red - My Pelican Gallery - (Gone, but never forgotten )One Marine's View Igitur qui desiderat pacem, praeparet bellum |
Semper drive!
Great shots, Rick! This is exactly what I was hoping to find out.
![]() Thinking about putting my car up on stands through the winter to work on some projects. This is awesome, THANKS!!! Randy
Lift point:
![]() Stand point: ![]() Lift and stand point: (Stand w/arrow) ![]() I usually just use the jack and adapter and lift from the side and place the stands under the car.
Rick 88 Carrera Targa -- There are only those that know and those that do not!!! -- |
