Radiator-style Carrera oil coolers
Does anyone have the dimensions for the external, radiator-style oil coolers that were first fitted to the '83-84 Carrera 3.2?
Matt Holcomb
1974 911 Carrera 2.7 RoW
1975 Mercedes-Benz 280SE
Dedicated Homepage
Engine Rebuild Homepage
Porsche Owners Gallery Profile
Pelican Gallery Profile
Old 05-29-2002, 06:35 AM
Buy them, sell them
Adam's Avatar
*bump*
Anyone?
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 05-29-2002, 10:42 PM
Steve W's Avatar
I thought the 83-84s came with the 21? row brass tube type cooler, and the radiator ones came during the later years.
Old 05-29-2002, 10:58 PM
CamB's Avatar
Why the question? As opposed to the factory ones, there are Mocal aftermarket ones on offer - try http://www.batinc.net (ouch on the prices for those downunder). I know there are plenty of others too. I understand it is more a matter of what fits...
The RX7 cooler is apparently a favoured (cheap) alternative (I'm getting one... I hope it works well). They look like this (ugly!):
It is much narrower, but quite thick and long.
That is a Mocal thermostat in the background too. I'm not helping the ugly factor with the blue hoses - but they are much cheaper and easier to work with than the braided hose.
1975 911S (in bits)
1969 911T (goes, but need fettling)
1973 BMW 2002tii (in bits, now with turbo)
Old 05-29-2002, 11:48 PM
Cam,
And the RX-7 cooler fits?
Matt Holcomb
MFIWDP
Dedicated Homepage
Old 05-30-2002, 12:15 AM
Buy them, sell them
Adam's Avatar
Cam,
I've got an RX-7 oil cooler lined up also. I'm keen to see if they fit or not. They're a steal compared to the OEM "Carrera" unit!
Old 05-30-2002, 12:32 AM
CamB's Avatar
Well, yes - it must because other people do it and it is on my car, but...
My car is in Christchurch (about 800-900km away) getting the work done, so I can't go and see it! The cooler definitely fits - it was mounted up this week, but I have no pictures yet and can't describe it.
I will take and post plenty of pics when it comes back in another couple of weeks.
Things to remember with the RX7 cooler (this is based on my discussion and memory - I didn't actually do it):
(a) it has some sort of built in pressure limiting device (good, as if the thermostat ever fails and cold oil goes to the cooler it will stop it trying to blow itself up)
(b) it needed the standard attachments removed and welded closed and new, -12 AN fittings welded on. This is partly personal preference (you could probably use an adaptor to the Mazda connectors). A pair of aluminium weld-on -12 male connectors are needed (about NZ$30-40 each, I think). Cooler was cheap - NZ$225.
Hope this helps.
Cam
1975 911S (in bits)
Old 05-30-2002, 02:06 PM
davis911s's Avatar
OK SO what year RX7 Coolers will fit???? And is it worth it and fairly easily modified? How much better is this than the loop cooler (when it is working )
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 05-30-2002, 02:27 PM
Early_S_Man's Avatar
Porsche Crest
Matt,
I don't think the Mazda cooler is intended for right 'wing' (fender) replacement of the trombone loop cooler! All of the pics I have seen have been installed in the bumper of RSR 2.8 (early cars) or IROC (RSR 3.0) style bumpers!
I have one of the Mazda coolers with the AN-12 fittings on it, which will have to be cut off and replaced with AN-16 fittings for me to use ...
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 05-30-2002, 02:32 PM
