EMBPilot's Avatar
coolant leak along side of radiator
after getting the fans down i was able to pressurize the system to about 15 PSI. the needle holds and will taper off over several minutes, but while its at the top there is a drip from the bottom left of the radiator pan. drips about once per three seconds.
I just fixed the top overflow fitting and the ones beneath it look fine, just some residue from the old leak. aside from that they are dry.
fix one leak and another pops up. this looks like it just sort of oozes down the silver bezel that attaches to the black side of the radiator...
should i remove the radiator and take it to a radiator shop?
any other ideas?
1995 993 C2
Old 12-11-2006, 01:15 PM
jezza944's Avatar
I had the same thing about 6 months ago. Took the radiator out. The shop here only charged $30Aus to give it a clean and re-seal the ends.
Apparently its a common leak on our cars.
Dave Jezza
http://www.pelicanparts.com/gallery/jezza944
1984 944na Krystalgrun (Crystal Green)
Old 12-11-2006, 03:04 PM
That Guy
Techno Duck's Avatar
Take it out and have a radiator place resolder it.
The 944 radiator is a nice piece, but the plastic end caps are what kill it.
I need to fix my fan switch sometime, gasket is starting to leak. not looking foward to dumping the coolant again.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-11-2006, 03:16 PM
Greasy Member
many944s's Avatar
Ditto.
Had the same leak on one of mine (85) about a year ago. Took mine out, local shop charged $32.25 for cleanout and reseal.
Radiator leaks can be a nightmare! First they will leak, then they crust up and seal themselves. After a month or so they open back up. Just when you think youhave it fixed, another will pop up.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 12-11-2006, 03:18 PM
EMBPilot's Avatar
guys thanks, when we get a good streach of bad weather here i'll drop the radiator out and take it to the rad shop, i feel a little better now. i understand that there are some set bolts at the top and once those are out it just 'drops out'.? (judging from clarks)
when they ask what kind of car its for what did you tell them? i hate saying its a porsche casue then i feel like i get one of two answers 1) we cant do it 2) your 30 dollar job just became 100
thanks a million.
1995 993 C2
Old 12-11-2006, 04:15 PM
That Guy
Tell them its for an old VW Jetta or a old Audi 100..your winter 'beater' car. .
Jon
Old 12-11-2006, 05:00 PM
EMBPilot's Avatar
lol perfect
1995 993 C2
Old 12-11-2006, 05:51 PM
EMBPilot's Avatar
friend of mine who owns an auto body shop said a radiator with plastic sides cannot be soldered. something having to do with the heat to resolder messing up the soldered stuff on the inside of the radiator AND it not being compatable with plastic, that my "best option" is to spend 2 and a half bills on a new radiator.
your mission, guys, is to dismiss the above facts.
1995 993 C2
Old 12-16-2006, 11:38 AM
Mein Gott!
Panzer909's Avatar
thanks a million.
An "Old beat up '86 Scirocco" is my standard answer. Never say the P word unless you absolutely have to
Johnny
1987 944S
1984 944 (R.I.P.)
1972 Triumph TR6 - 100% trouble free between breakdowns
2003 BMW 325xi
Old 12-16-2006, 01:19 PM
Dana Norris's Avatar
Porsche Crest
I had the exact same problem with my first 944 a 1984, removed the rad.
and took it to a shop known for good work and recommended by a good friend.
The guy took one look and said that with plastic sides with an alum. core the seals would not withstand a hot flush and he did not have the tools to separate the sides from core even if he could find the seals. To make a long story short I got a good used rad. for $75.00
________________________________
1986 944Na just got it 3 weeks ago
First Porsche 1984 944 NA
Second Porsche 1969 912 upgraded with 2.4 CFI
Third Porsche 1976 911S upgraded with 1983 SC 3.0
Old 12-16-2006, 01:38 PM
jezza944's Avatar
I think some shops just don't want work! My shop pulled the plastic ends off, put in new seals, soldered a small hole, re-soldered the bottom mounting lugs, painted it black, Aus$30. (about US$23.50)
Yep Kevin, it CAN be done.
Dave Jezza
Old 12-16-2006, 05:21 PM
EMBPilot's Avatar
Just thought id put this out there for anyone with future projects.
there are kits on ebay for 944 complete cooling system hoses. I think they are a little over priced and dont come with the hose clamps.
here is a mostly complete list of cooling system clamps and hoses for a later 944NA
im doing the radiator with a used one that seems to be in good shape, while its out, i figured id might as well get these crusty clamps and old hoses off.
the only parts i didnt replace was the overflow fitting (cause i just got it like two weeks ago), Thermoswitch (working), and the overflow hose from the rad to the tank (appears to be just fine).
heres the list for referance.
HC-90-110-9-M130 $1.25 1 $1.25
Hose Clamp, Adjustable, 90-110mm, each Brand: Gemi
HC-32-50-9-M130 $0.75 2 $1.50
Hose Clamp, Adjustable, 32-50mm, each Brand: Gemi
HC-70-90-9-M130 $1.25 2 $2.50
Hose Clamp, Adjustable, 70-90mm, each Brand: Gemi
HC-40-60-9-M130 $1.00 4 $4.00
Hose Clamp, Adjustable, 40-60mm, each Brand: Gemi
HC-12-22-9-M130 $0.50 2 $1.00
Hose Clamp, Adjustable, 12-22mm, each Brand: Gemi
HC-25-40-9-M130 $0.75 6 $4.50
Hose Clamp, Adjustable, 25-40mm, each Brand: Gemi
944-106-353-01-M100 $9.50 1 $9.50
Radiator Drain Plug w/ Seal, 924S/944/968 all, each Brand: Genuine
Porsche
944-106-241-03-M101 $4.00 1 $4.00
Water Hose, Water Pump to Heater Pipe, 924S/944S (1987-88), 944 (1983-
89), 944 Turbo (1986-89), Each Brand: Elaplast
944-106-245-02-M260 $34.75 1 $34.75
Water Hose, Radiator to Coolant Expansion Tank, 944S (1987-88), 944
(02/85-88), Each Brand: OEM
944-106-239-07-M101 $15.50 1 $15.50
Upper Radiator to Cylinder Head Hose, 944 (02/85-89), Each Brand:
Elaplast
944-106-237-07-M101 $12.50 1 $12.50
Lower Radiator Hose To Water Pump, 944S (1987-88), 944 (02/85-89),
900-123-118-30-M131 $0.50 2 $1.00
Washer for Thermoswitch, As Needed, Each Brand: Fischer & Plath
951-106-107-00-M136 $2.00 2 $4.00
Radiator Mount, Lower, 2 Per Car, 944/944S/944S2/944 Turbo/968 (02/85-
95), Each Brand: OEM
944-106-928-00-M100 $2.75 1 $2.75
Seal for Radiator Fitting 944-106-927-00-M100, 924S, 944, 968, Each,
Each Brand: Genuine Porsche
cheap cooling system insurance for around 90 bucks.
i added some bonus stuff too...
a new Jboot, Intake gaskets, and fuel injector reseal kits incase i ever decide to send the injectors out to be cleaned.
1995 993 C2
Old 12-18-2006, 08:55 AM
Razorback1980's Avatar
Kevin...you may also check the For Sale forum. Someone on here was offering a complete aluminum radiator for sale for a manual transmission car. I can't remember the price, but I'm sure a search will yield the thread.
Tom
1990 944S2 Cabriolet
2002 Chevy Silverado 2500HD
2003 Maroon Ford F350 dually
Old 12-18-2006, 03:19 PM
EMBPilot's Avatar
thats where i found it tom, its a low mile rad, the guy was great, hes a user here.
1995 993 C2
Old 12-18-2006, 05:37 PM
EMBPilot's Avatar
So i go out and buy $100 of new hoses, clamps, gaskets, mounts from PP, then bother countless people to try and track down a good radiator, nail one down, get it here, all the parts ready to go... been driving the car for several weeks since this popped up...
now the thing STOPS leaking?! Not a freaking DRIP!
1995 993 C2
Old 01-03-2007, 03:21 PM
jezza944's Avatar
That sounds normal, the crap seals it for a while, then it decides to leak again!
Good luck. I'd fix it anyway, there's nothing worse than dumping your coolant on the white line on the h'way.
Dave Jezza
Old 01-03-2007, 04:33 PM
EMBPilot's Avatar
Hey guys i was getting this radiator ready for installation today by cleaning it up. I plan on putting this in (even though mine leak appears to have stopped for now). I was planning on doing this when the rest of the parts get here for all the crap under the intake.
i noticed when i started to take a closer look at this unit there are these fittings on the passenger side of the rad. when i flushed the rad out, no water came out of these fittings.
my current radiator DOES NOT have these fittings!
what are these for? can i still install this to replace my current one?
1995 993 C2
Old 01-13-2007, 03:16 PM
That radiator is for the auto-trans model. You can use it.
Old 01-13-2007, 04:42 PM
EMBPilot's Avatar
what do i do about those fittings? is it okay to leave them the way they are?
1995 993 C2
Old 01-13-2007, 05:55 PM
That Guy
You can leave them open, i would just plug them with an appropriate size bolt if you can find one.
Jon
Old 01-13-2007, 06:00 PM
