lowbob84's Avatar
Air Oil Separator
For my 951, is there an easy way to take out my Air-Oil separator without having to take out the turbo? It seems like no matter which way I look at the problem, the only way to get to the lower mounting bolt is to take out the turbo so I can remove the heat shield to get to the last bolt. Am I wrong, please let there be an easier way to get it out. Thanks.
Old 05-24-2008, 11:31 AM
I'm sitting at the exact same place you are..... My only redeeming factor is that all of the bolts that hold that heat shield seem to have fallen out at one point or another. My lack of patience in this matter has led me to start 'destroying' said heat shield. I almost think I've bent it enough to get out through the bottom once I drop the front section of the exhaust.
I think I'll just wrap the downpipe with header wrap to cut down on the heat, and say that I pulled it for 'weight loss'.
Jack
86 Porsche 951 - LR 3" Exhaust, MaxHP chips and ProfecB @ 15psi
83 Porsche 944 - Still under re-construction.
08 Suzuki Boulevard M109R LE
02 Nissan Altima SE3.5
Old 05-24-2008, 05:40 PM
