air pump advice
i have a 79 sc 3.0 all stock i live is kansas so there are no laws on smog. i want to get more room in the back i just need to know how to plug off the distribution pipes and the injection.
by doing this i think i will have to change my air/fule mix?
i do not know how to do that .
thanx
corey
Old 12-14-2003, 12:42 PM
beepbeep's Avatar
Take out the pump and lines and plug holes in heads with 10mm plugs with 1-mm thread pitch.
Thank you for your time,
Old 12-14-2003, 01:01 PM
Bravo's Avatar
You can buy some "caps" for the cylinders under the car where the air is injected into the cylinders and remove everything else. I dont believe you will need to adjust air/feul but I could be wrong-- I didnt -- you can buy the plugs for cheap I just did it-- have fun.
Dean
1978 SC Targa Euro
1966 911 Coupe Restored/Burned/Sold - In that Order
were do you get the plugs at ? will this give me any more hp?
Old 12-14-2003, 01:28 PM
makaio's Avatar
Just call Pelican in the AM and explain to them what you want. They will hook you up.
Old 12-14-2003, 01:33 PM
Bravo's Avatar
no --- no more noticeable hp-- Sorry
Dean
1978 SC Targa Euro
Old 12-14-2003, 02:00 PM
well i got all of the air pump stuff off tonight. i am having a time finding the bolts to go back in but i think i will find them. thanx
corey
Old 12-16-2003, 08:12 PM
Bravo's Avatar
did you call Pelican?? If they dont have them others do
Dean
1978 SC Targa Euro
Old 12-16-2003, 08:36 PM
smestas's Avatar
Send a message via AIM to smestas Send a message via Yahoo to smestas
Heres a previous thread on the plugs.
air injector plug size
Simon Mestas
'78SC Coupe
My Pelican Page | AlfaBB - Alfa Romeo Forum
Old 12-16-2003, 08:47 PM
Cool
thermal reactors should be removed before disconnecting the air pump, IMO
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-16-2003, 10:04 PM
thrown_hammer's Avatar
Get Mercedes Benz Transmission drain plugs. They are cheap.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 12-17-2003, 03:54 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Don't think any SCs came with thermal reactors did they?
1981 SC ROW Coupe
Old 12-17-2003, 04:39 AM
Cool
I don't know ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-17-2003, 07:44 AM
After you take the air pump out and dicsonnect the rubber tube that connects to the pipe assembly in the engine compartment, you can leave the air pipes in place. They won't effect the performance at all plugged or unpluged.
Here in CA, we put the air pump in every 2 years for smog, then remove it and run the car 'til the next time without plugging anything and there is no difference in performance.
The pipes don't acutally go into the cyclinders. They inject air into the exhust path for some unknown reason. All I can figure, is that it somehow dilutes the exhaust emmisions so it can pass smog inspection.
If it doesn't leak, you're out of oil.
If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt.
Screw Flanders....
I'm goin' to Moe's.
Old 12-17-2003, 07:51 AM
Senior Member
Jdub's Avatar
Be sure to save all the bits for the next owner.
John
'78 Targa in Minerva Blue
Old 12-17-2003, 08:19 AM
