Can I stick a pressure washer wand in here?
Also, does anyone know where to find new rubber boots for the alternator connectors? Thanks,
Cabrach
CConnor
73E targa
89 Coupe
Old 07-14-2004, 07:06 PM
TurboRuf's Avatar
Ewe!! Looks like the Thermostat O-Ring went south and it's been leaking a little.
I used some SimpleGreen and a couple of rags to clean my Thermo leak. Not sure about a pressure washer though.
Old 07-14-2004, 07:27 PM
Randy Webb's Avatar
I would use a shop vac and scraper first. The idea is to get the stuff out of there, not to drive it into the crevices.
It's best to keep simple green away from Al -- or so says the USAF.
Old 07-14-2004, 08:14 PM
Crachian,
That stuff has to come out. Randy is right on.
Looks like it is blocking head cooling fins on the left.
Ultimately the source of that Goo must be found and fixed.
Could this be dust mixing with oil mist? Dirt roads?
Don't sweat the rubber boots. Disconnect the battery before removing the alternator.
Good Luck and let us know what you end up doing.
DOUG
'76 911S 2.7, webers, solex cams, JE pistons, '74 exhaust, 23 & 28 torsion bars, 930 calipers & rotors, Hoosiers on 8's & 9's.
'85 911 Carrera, stock, just painted, Orient Red
Old 07-14-2004, 09:46 PM
Try your local aviation store. If this doesn't work send me the dimensions and I see what I can find.
"The greatness of a nation and its moral progress, can be judged by the way its animals are treated." M. Gandhi
1977 911S...sold; 03 F20C; 2009 VW Jetta Sportwagen
Old 07-15-2004, 12:30 AM
