Barback King
Rapid Dog's Avatar
Question Barback Longer Hose Inquisition
O.K., O.K., inquiring minds want to know...
I have several people asking me what the PN# is for the longer brake hose when one goes from low bars (below top tripletree) on a NON-ABS bike to above the tripletree with barbacks....since I never done it myself I don't know.
Let's help the bruthas out.
I know most guys n gals just go to steel brakelines at this point, so, any pertinent nfo on where and what and how would be helpful.
Thanks,
Brutha Rapid
R11S CNC BARBACKS
Old 05-03-2006, 03:12 PM
The bike :
1999 low bars with no abs
With the barbacks I used Goodridge lines
-right side is 26" ( excluding the fittings on each end )
-left side is "28"
-I ran double lines from a double banjo bolt on the m/c.
There is no need to add a new throtle cable if you tuck the cable behind the ignition key cylinder. Secure it losely with a zip tie. If it is allowed to remain in it's normal position it will cause the bike to race.
This is one area that was a little unclear when I did my research.
I was releived to know the cable didn't need replacing.
Gary
Old 05-03-2006, 05:14 PM
unsafe at any speed
wswartzwel's Avatar
Real OEM has the lengths and part numbers Rapid, HERE is a link to their site. For those without ABS the numbers for the 2 different hoses are.
L=675MM 34322331902
L=639MM 34327651552
I did a search here at Pelican and saw where you asked the same question back in 2003, but no one was able to give you any part numbers. Hope this helps.
Bill
Bill Swartzwelder
Old 05-03-2006, 05:16 PM
Here is information from Suburban Machinery for their R11S Handlebar Riser Kit:
On non ABS models a longer brake hose is required.
For Brembo calipers (99 thru Jan 2001) use BMW part # 34-32-2-331-915
For BMW EVO calipers (Feb 2001 thru today) use BMW part # 34-32-7-651-553
Mike
Old 05-04-2006, 07:42 AM
Barback King
Rapid Dog's Avatar
Thanks guys, that's all good info!
R11S CNC BARBACKS
Old 05-04-2006, 08:17 AM
Gary,
Did you somehow disconnect the throttle cable inb order to tuck it back behind the ignition switch? Can't see how you did this with all the cables and wires behind it.
Old 05-15-2006, 06:36 PM
ploz58's Avatar
Send a message via Yahoo to ploz58
Can anyone confirm, what is the hose length for a non ABS 2001 going to barbacks?
Thanks in advance
Phil,
Australia
BMW 2001 R1100s
BMW 2003 R1200CL
Old 02-06-2007, 10:09 PM
Barback King
Rapid Dog's Avatar
ploz,
do you have low bars or comfort bars (above tripleclamp)?
Low bars will require about -2" longer hose. Good time to go steel.
Otherewise no hose is needed with the high (comfort) bars.
R11S CNC BARBACKS
Old 02-07-2007, 07:53 AM
MarkR11S's Avatar
Off topic here but Rapid I saw your add in the latest BMW owners mag. NICE! Anyway, keep up the good work.
Mark
2004 R1100S
2004 HD FLH-P
Old 02-07-2007, 08:11 AM
Barback King
Rapid Dog's Avatar
danka marka
R11S CNC BARBACKS
Old 02-07-2007, 08:17 AM
Send a message via AIM to xgironx Send a message via Yahoo to xgironx
hey all
i have an ABS 2004 R11S.
Had my dealer move the comfort bars moved under the triple-clamp a while ago. Am planning a trip from DC to NHampshire and have a set of barbacks to install.
I have a coupla questions:
--Am i likely to need longer throttle or brake lines to do this?
--Is this something I can likely do on my own without too much consternation?
--If so, your recommendations on torque values?
thanks
justin
2004 r1100sa mandarin // laser race pipes (non-daytona ) // techlusion module
Old 06-10-2007, 04:22 PM
I wanna Live 'til I die!
signit98's Avatar
Send a message via AIM to signit98
...no, Justin... not if you had them up there already... then you should be fine.
Light travels faster than sound. This is why some people appear bright until you hear them speak...
https://www.facebook.com/Uncommon-Adventures-by-Rick-Ralf-681965548931729
2005 R1200GS - 2006 Suzuki DR650 - 2011 Husky TE250 - 2014 KTM690 Enduro - 2022 Husqvarna Norden 901
Old 06-10-2007, 05:11 PM
Barback King
Rapid Dog's Avatar
yes no yes
Justine,
If your bike came form the factory with ABS you should be good to go.
Most questions can be sorted out if you go to my webpage:
www.rapiddog.net and click on "lowbars".
I designed these and the worked for my 2001 R1100SA.
My bike has ABS and comfort bars from the factory.
Everyone else sorted out their problems themselves.
Consensus is that you won't need anything if you have ABS.
That said, this month I had a guy ask if he could return his set because he couldn't get his throttle cables to work.
This was the first ever out of maybe 400 sets...odd, yet weird...
All the experience with installing the barbacks is from the guys who've ordered them. There is some discussion about the need for an accelerator cable. One guy said you need to buy one, then someone figured out that re-routing gave it more slack. Read the entire discussion.
Suffice to say, if your '04 ABS bike should be a snap, especially if it came with comfort bars (above the top tripleclamp.)
E-me if you need help...
Love,
Rapid
R11S CNC BARBACKS
Old 06-11-2007, 08:38 AM
There are two throttle cable lengths depending on which bars your bike came with. I installed the longer cable on my wife's 03 Prep as the shorter length didn't cut it with the KRS bars she used for awhile.
John B.
03 R1100S Prep(wife's), 02 Futura, 92 907ie, 89 Transalp, 87 R80/100, 82 Morini 3.5 sport, 76 R90/S, 73 R75/5
90 535im & 95 525i Touring
65, 66 Alfa Romeos
Old 06-12-2007, 06:23 AM
thanks for your reassurances.
i've never actually pulled the triple clamp off a bike. i plan to borrow a torque wrench. any stuoid pet tricks i should avoid?
thanks again
justin
Old 06-12-2007, 06:28 AM
Barback King
Rapid Dog's Avatar
Justin, no need to pull the top tripletree. You'll be loosening the top and bottom clamp screws (bolts) and sliding the fork tubes up thru the clamps far enough to accept the bars or barbacks.
Please be careful to re-torque everything to spec....but ofcourse we're not qualified to give you professional advice.
R11S CNC BARBACKS
Old 06-12-2007, 09:17 AM
LeftCoast Peter's Avatar
Below the tripple to barbacks: If you planning to go steel (and why not) I found getting a Spiegler r1100s kit and ordering 80MM longer than stock for the top hose is about perfect (a tiny bit on the long side). You could get away with 75MM.
Old 01-31-2010, 12:10 PM
