Clutch still getting stuck
i checked my records... i replaced the clutch master cylinder last year... im thinking its not the slave cylinder, because the brake fluid has been at the same level, and no signs of fluid in the carpet. ive even added extra fluid and no sign of improvement. Also the spring is still engaged so its not that.
if i rest my foot, just the slightest bit on the clutch, i can feel it being grabbed, and it is pulled all the way down. i have to dig my foot behind it and pull it up, real annoying.. but most of the time it just comes back up only half way.
Any suggestions?
i was thinking of bleeding the brake fluid, any easy way to do that??
thanks
-Derrick
1987 924S
1999 Carrera 4
Old 08-12-2007, 10:36 AM
Bleed the clutch hydraulics using a motive power bleeder, while the rear end of the car is about 2 feet higher than the front of the car (think jackstands).
Good luck, George Beuselinck
Old 08-12-2007, 10:58 AM
im going to attempt to bleed them,
But one question, where is the valve to bleed the brakes?
thanks
-Derrick
1987 924S
1999 Carrera 4
Old 08-13-2007, 10:12 AM
Used & Abused
Have you checked the clutch pedal linkage? I had something like this happen years ago where the clutch pedal would stick in a certain spot. Turned out to be the clutch pedal linkage was binding.
I crawled into the footwell with a can of PBBlaster(?) and some 3 in one oil. Sprayed the joints one by one and tried the clutch till I found which one it was. A few drops of 3 in one oil and it hasn't given me trouble since.
Hope it helps
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 08-13-2007, 04:52 PM
The bleeder is on the top of the slave next to the starter. It is possible to open the bleeder without removing the starter but its much easier if you remove the starter. I just went through what you did. It ended up being the clutch disk. The peddle would stay on the floor. Everything else was ok. If (when) you pull the starter look for friction material in the bottom of the bell housing.
Don
Old 08-13-2007, 06:07 PM
thanks
-Derrick
1987 924S
1999 Carrera 4
Old 08-13-2007, 07:06 PM
Send a message via AIM to Lapponia
Derrik!
You did the master cylinder last year you said. Why did´nt you do the slave cylider as well??
Do that as a first job here, then flush the entire system, bleed and you will be fine. Look at the picture here and you can see the coiled spring that will keep your pedal down when you have this kind of issue. The spring is to the right of the fuse board.Do notremove the spring. It´s a h......l to put back and there is no need to do that. So, change the slave.
Rolf
944 - 84 NA
Old 08-14-2007, 01:28 AM
adrian1's Avatar
Porsche Crest clutch.....
I have the same problem now with my 86 951. Whenever i tap the the pedal it just goes down or if slowly let off the clutch it will go back down. I tried to bleed the system 4 days ago. I took out the started and lifted the rear higher and had a friend pump and depress the pedal. After severval tries it would still have the same problem where if you pump it quickly it would be fine but slowly the pedal would go down by it self and the fluid level in the resevior would rise as it went down. However if he pumped quick and it was fine the fluid would remain at the same level, it would only rise if it went down by itself....I thick its the slave cylinder... Anyone have previous experience with this that can shed some light on us????lol..........
1986 PORSCHE 951 3.0 project has begun!
1989 IROC-Z(Show Car)
1961 Willys Jeep w/ 283 chevy(straight open headers)
1995 Dodge Ram 2500 HD
1981 Corvette 4spd
Old 08-18-2007, 10:29 PM
DarylJ's Avatar
Send a message via AIM to DarylJ Send a message via Yahoo to DarylJ
I just replaced a slave cylinder for the exact reason adrian1.
And it wasn't even leaking enough to see any fluid under the car.
And let's be clear, because the first post in this thread seems to have it backwards: the master cylinder is under the hood by the brake reservoir. When it goes bad, you often see fluid on your carpet. The slave cylinder is in the bell housing on the left side of the starter. You usually see fluid in your driveway when this one goes bad.
And if you're changing either, change both - it's just a good idea. And, as mentioned, spend the few bucks on a motive power bleeder. You can't get the same pedal feel with anything else (other than a professional pressure bleeder). While you're doing this, just change all of the fluid in the system out - brakes and clutch. It won't take more than a gallon - probably much less once you get good at bleeding.
Old 08-19-2007, 07:22 AM
adrian1's Avatar
Thanks ill start looking at prices for a slave cylinder, master cylinder, and a motive power bleeder.
1981 Corvette 4spd
Old 08-19-2007, 01:02 PM
Let's go shooting.
Dark Skies's Avatar
Originally Posted by DarylJ View Post
... When it goes bad, you often see fluid on your carpet.
Not always - when mine went I only discovered it because I was swapping the beige carpet interior for black. When I lifted the carpeting I discovered fluid UNDER the carpet where it had leaked down at the point of entry in the firewall. Because the carpeting is waterproofed on the back I didn't discover it until quite by chance. Worth sticking your finger right up under the point of entry to see if there's fluid leaking.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 08-19-2007, 06:14 PM
adrian1's Avatar
I found a motive power bleeder with the adapter for $45. And I need a new cap for the reservior because mine is missing the top and it won't hold pressure. I found one for $10. Im ordering these today and have to look into the master and slave cylinders... Ill keep you posted.....
1981 Corvette 4spd
Old 08-21-2007, 07:18 AM
meister member
speedracing944's Avatar
You can measure you clutch friction disk wear by removing the inspection hole cover.
Check on www.clarks-garage.com and look under "Clutch Disk Wear Check" for the procedure.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 08-21-2007, 08:54 PM
adrian1's Avatar
Well I found both the clutch master cylinder and the clutch slave cylinder for about $58 each and $6 shipping. They are FAG BRAND, I found them on ebay what you guys think???
Im also getting the power bleeder for about $45 and a used brake master cylinder for $5 just for the cap.....
1981 Corvette 4spd
Old 08-21-2007, 09:20 PM
DarylJ's Avatar
Sounds like decent prices. And I'm pretty sure FAG/FTE is the stuff that comes on the car from the factory (at least that's what was on mine when I replaced them).
Word of caution - when I replaced my master I THOUGHT I was having a hard time getting everything bled. I couldn't get the clutch pedal to return more than an inch or so. Turns out I didn't adjust the clutch linkage properly - I shortened it up and everything has been great for 3 or 4k miles now. So make sure you measure the length of that rod/linkage better than I did when you take out the old master and swap the linkage to the new one.
Old 08-22-2007, 05:26 AM
adrian1's Avatar
Thanks DarylJ ill be sure to do that before i take it out. I ask if i have any problems.
1981 Corvette 4spd
Old 08-22-2007, 06:05 AM
adrian1's Avatar
I checked today under the carpet like dark skies said and found allthe fliud leaking from next to the pedal under it but the carpet for the most is dry. I got everything ordered and should starting working on it by monday.
1981 Corvette 4spd
Old 08-23-2007, 12:29 PM
ok got the clutch checked out today,
def the slave cylinder
where's the best place to get a cheap slave cylinder
cheapest i found was $75.00
-Derrick
1987 924S
1999 Carrera 4
Old 08-27-2007, 06:31 AM
adrian1's Avatar
i got mine on ebay for $57 and $65 with shipping hold on let try to find it...
1981 Corvette 4spd
Old 08-27-2007, 09:24 AM
adrian1's Avatar
http://cgi.ebay.com/ebaymotors/1984-Porsche-944-Clutch-Slave-Cylinder-New-in-Box_W0QQitemZ120155081154QQihZ002QQcategoryZ34199Q QssPageNameZWDVWQQrdZ1QQcmdZViewItem
1981 Corvette 4spd
Old 08-27-2007, 09:30 AM
